On the rectifier board remove all fuses except F6 and power up.
If F6 holds without blowing add the fuses in one at a time until you
determine which circuit is causing the F6 to blow.
You can check your varistor with fuse F4 removed power off using a meter. Measure for low resistance.
If you leave F4 installed, you will see a low resistance because of the transformer winding. A shorted varistor
will cause F6 to blow. The varistor protects the machine from high voltage surges and can commit suicide by shorting and blowing F6 to protect the machine.
Transformer outputs can be checked with a voltmeter set to AC, test points E3 to E4 should measure 49VAC
E5 to E6 should measure 11.3VAC, E7 to E8 7.3 VAC, E9 to E10 7.9VAC, E11 to E12 12VAC. You can sucessfully measure all these test point with all fuses removed with the exception of F6.
