I have a Stern Stars that I am having display issues with. What it does: When powered on, it boots up properly, with the proper flashes, then goes into attract mode. I can then coin up and play a full game with no issues. The problem is I have no displays. I discovered earlier today that if I complete the test switch circuit, the displays come on. SO, I turned the machine off, jumped the test switch, and the game came up normally, attract mode, coined up, played a game, but now the displays are on. What has been done to this point: the displays are all brand new Uno boards from Pinitech, the rectifier board has been rebuilt. SO, with all low voltage displays, F2 fuse has been removed as high voltage is no longer needed. The battery looks ok, but tomorrow, I am going to remove it altogether.....it will later be replaced with NVRAM. Any ideas? Thanks.
