Still hoping someone out there may have some advise for my startup issue. Brief update; I solved the ball search playfield activity issue, that was related to the ball having up at the very left end of the trough, solved & fixed.
But, I am still occasionally and randomly - having th issue where the ball will start, does not let you select character or path, it goes right to play. some times immediately on game start, other times you see the path selection screen and the ball starts when you hit the right flipper button to advance between choices ?!?
I want to think its the action switch, but the switch appears and works fine, it gets hit a hundred times during a game for tie fighters and never has an issue. I am wondering about the node board that the action switch plugs into, or something else??
its really strange, you can play 15 - 20 games, then suddenly bam, doesn't let you select, goes right into play, does it about 3-4 times, then its normal again
help ?!?
thanks!
m
