Good morning/afternoon,
I'm having my left white GI playing tricks on me.
Essentially: there's a short somewhere in the circuit, causing overcurrent detection. Originally the issue was random, then I found a pattern and could replicate the issue by simply triggering the left flipper. It's now persistent.
So my first thought was a short below the flipper coil mounting plate, no luck, wires are soldered cleanly, no identified issues. I tried identifying visually on the other sockets, no luck.
I did confirm using a DMM that there is indeed a short in the circuit. If I unplug CN15, the overcurrent detection is gone, which is coherent with a short on the circuit itself
So, a few questions:
- Did you ever had a case where the light bulb socket would actually create a short ? Never seen that before, but you never know
- Did you ever had a case where a LED light would actually create a short if defective ?
- Since it's now completely off, I have to manually trace the wires to identify where the left white GI would be. I would appreciate if someone would be kind enough to take a picture highlighting where they are (using test mode)
Thanks and regards
