Quoted from Lermods:Can someone please explain how the multiplier works?
I hit the button and the screen moves the multiplier from red to green, a few inserts on the pf turn green. Im assuming it is those shots that now get the multiplier? So each one scores a multiplier or do I need to hit all the green arrow shots to collect it.
How do I know how much those shots are worth?
I've seen it mentioned you can move the multiplier, how Is that done?
How do you build the multiplier?
Thx
The multiplier current level is always displayed in the top middle of the big LCD.
Red means off. Green means on. If they are red, use the flipper buttons to move the X shots around the playfield. Press the action button when you have them on shots you want. They will turn green and stay on those shots. Now all of those shots are multiplied by the current multiplier value.
Increase the multiplier through choosing it at start of ball or hitting the standups under mini LCD. Hitting those standups increases multiplier by one.
As your multiplier gets higher and higher, the shots that are multiplied reduce. So when the multiplier is like 5x, three shots are able to be selected. When you get all the way up to 40x only one shot can be multiplied.
It doesn't matter whether you have the multiplier on or off, you can increase it by the stand ups. The only reason to turn it off is to be able to move it to a different shot on the playfield.
Also, hitting the drop targets down a certain number of times will double the current multiplier value.
Max multiplier is 40x (may have been reduced with new code)
If you ever heard a thumping sound while playing (chunk chunk chunk chunk) that is the multiplier timer running out. Shoot the standups to keep them running. If that timer runs out your multiplier goes back to 2x.
