Quick post tonight before I go to bed.
I'm attempting to reverse engineer the RGB protocol used on the Stern Star Trek LEDs.
With some help from a fellow Pinhead here in Austin; we observed that the RGBs are being enabled via a custom microcontroller which speaks RS485 with the main CPU board in the backbox. This RS485 buss is then used to enable the various LEDs with some kind of instruction set.
With this observation; I bought a USB RS485 adapter from Sparkfun and then made a custom RJ45 cable which plugs into an empty RJ45 connector on the LED boards.
I then hooked up an Oscope and measured the smallest pulse width on the buss and measured ~8-12uS. Running the reciprocal of that gives me a baud rate which approximates 115200.
With that data; I set my RS485 adapter's com port to 115200, 8bit, no parity, 1stop bit... and captured some traces.
I'll post these traces tomorrow if some people agree to "group project" this and share the data / findings. I don't want one person "cornering" this info and attempting to prevent the others from making similar products. I'm being open about this - for the "group mind".
My end goal is "simple". I want to decode the protocol so I can interface it to the ColorDMD and change colors to match the mods currently in play. IE: Nero = purple, Save the Enterprise = green, etc. IF I can figure out the protocol then "in theory" it'd be possible to enable a cheap microcontroller to snoop the RS485 buss and switch colors in time to the missions active.
