Just picked up a Star Trek and was looking to update the code.
Followed advice from several posts and have done the following:
- With the game off
- Formatted USB drive to FAT32
- Plugged USB into game
- Flip dip switch #8 to ON
- Power on game. DMD is blank
I tried using service menu option to update code with the game on and the game gets frozen and displays 'rebooting'
With game powered on, flipped #8 and inserted USB, pressed the white reboot button, game freezes on whatever screen the DMD displays when the button is pressed.
Tried new USB, same results. New game code off stern pinball website, same results.
So essentially, the game won't reboot. Game is stuck at v1.4.
Anyone have any ideas? First thumb drive was 32 GB USB 2.0 PNY, second was an older 4GB DataTraveler.
When dip switch 8 is on, the white reboot button freezes the game. If I flip the switch to off and hit the button again, the button produces a reboot.
Did some digging and it looks like the U9 says v1.0. Sounds like I could need to update this first.
Is this the part I am after? https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=U9+update
EDIT: U9 needed a reseating as one pin was visibly sticking out. If you have issues booting into update / issues w/ dip switch 8, this could be your answer!
