I got this game two weeks ago and the game still isn’t playable. Was told everything worked 100%, however when it arrived, unfortunately that wasn’t the case.
When the balls are in the trough a ST LE switch test should look like this when all is correct:
Each switch should only test one ‘square’ with the balls in a row on the upper left. Yet when I test the ball trough switches on my machine, each switch doesn’t activate just one square, but the entire column:
Last pic has all three ball trough switches activated. Even the shooter lane switch tests the entire column (not pictured), however the ball jam does not (the opto tests normal). Every other switch on the entire game tests normal. I’ve reinstalled the code... didnt help. No mods where added on the game. What in the world causes this and more importantly, how can it be fixed?
