i am going back over this because I am concerned that I missed something else beyond the yellow wire needing to be moved to lug 5.
Rikoshay --> you mention no wire to lug 7, looking at the manual for 16B-6 transformer, I see lugs 1 & 3 joined (AC RETURN) and lugs 5 & 7 joined (AC POWER) needed for mains of 120VAC. With 9 to 11 joined you should see slightly higher readings feeding 120VAC to a transformer jumpered for 115VAC.
Rikoshay --> as you mentioned your mains is 120VAC, i suggest removing jumper 9 to 11 and joining lugs 5 to 7, with the power off and unplugged from the wall.
also if you are doing this, you will need to move the yellow wire on lug 9 to lug 5 or 7.
again, be very careful when doing any of this.
Done on 3/26/2023
Rickoshay-->with that aside, I'm curious how you joined the mains and ground?
MarkAnderson--> I pulled an extra cord from another machine and put alligator clips on the mains and the return. I clipped the mains to lug 1 and the return to lug 5 and plugged the cord into the wall.
Rikoshay--> Is the transformer (lower panel assembly) out of the machine?
MarkAnderson-->I pulled the wood transformer panel out of the wall and I have to whole unit on the kitchen counter.
Rikoshay--> assuming it is, and with no plugs connected to the rec board, forget about applying power to J2 on the rec board, go directly to lugs 1 & 5.
MarkAnderson--> Done
Rikoshay--> With it now having the jumpers changed, 1 is tied to 3, and 5 is tied to 7.
MarkAnderson-->I did this but missed moving the yellow wire until now.
Rikoshay-->so your yellow wire is still pin 6 for J2 but going to lug 5 or 7, and pin 7 for J2 is still a white wire going to lugs 1 or 3. If this doesn't match with what you have can you please post a pic of your J2 plug before proceeding?
After changing the yellow wire to lug 5 my set up matches this with one exception. My wires are slightly different. I think that it is because mine is a stern 200 MPU. I traced the mains from the on off switch through the rec board to the transformer back to the rec and then to the switch. Black mains comes into the switch. The black mains is connected to the yellow mains. The yellow mains goes to pin 6 on the rec board. I followed the trace to connector E1 on the back of the board which is a red wire. The red wire goes to lug 1 on the transformer. The return is a yellow wire out of lug 5. The yellow wire connects to E2 on the rear of the rec board. Following the trace on the front it connnects to pin 7 which is blue and white on a stern mpu200. The blue and white wire connects to the white mains return wire at the switch.
The colors of my return wire is slightly different because my cpu is a Mpu 200. The wire that is white on stern mpu100 is blue white on mpu200. Also the knocker is in the body of the machine on mpu200 so there is no wite in connector 13. There is an additional Blue wire going into connector j1connector #3 because the Mpu 200 machines need more power in the 6VDC power rail for the playfield.
Rikshay-->with the new mains connected to the transformer, and your meter set to ACV, you should be able to test the winding pairs.
I will retest the winding pairs now.
