(Topic ID: 293474)
Stern/Spike 2 Diagnostics
By ScoobaDoo
5 months ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by pins4u
    #1 5 months ago
    I bought my first ever pin awhile back. It’s an Avengers AIQ Premium. Everything seems to working fine but I’m trying to run the diagnostic tests. Like the node, switch tests but I can seem to navigate through the menu to get it started. Does anyone have some kind of guide on how to run these tests?
    #2 5 months ago
    Bump
    #3 5 months ago
    Quoted from ScoobaDoo:
    Are you saying the coin door buttons themselves don’t work when you push them?
    #4 5 months ago
    Quoted from Lermods:
    Not at all. They all work fine. I’m just wondering if the specific tests run on their own or do I have to keep pushing the buttons during the test?
    #5 5 months ago
    It depends on the test. Switch tests you choose the setting then tap switches on top of the playfield and it will tell you which switch plus make a noise. Other tests, like coil tests, you may need to select a setting then hit the start button to fire the coil you’ve selected. Lastly there are lighting tests which typically light something for ever option you have on the screen.
    The one thing that can be confusing for a new owner is the interlock switch which turns off the high voltage when you open the coin door. For testing, you can pull the switch mechanism out to lock it always on.
    #6 5 months ago
    Easy - READ the manual!
    I know most people ignore the instruction manual but it's all explained in detail there.
