We have a Stern Rush LE. I have replaced the flippers and bearings with the Precision Pro ones. The problem isn't with the flipper mech, it's just that now the system is so efficient the power is incredible ( especially when the playfield has been waxed ) and I can't reduce the power setting any further.
I've come to the conclusion that for at least one flipper in particular ( the top right ) I need to do something about it.
All three coils on the machine are 090-5032's. I noticed on the Godzilla Premium/LE that the upper flipper uses a 090-5030 which if I am correct is a lower power.
Would there be any negative impact in any way if the coils were changed to 090-5030's ( ie node board, drivers etc ), does the code have the ability to take into consideration the current rating of each coil, or does it not matter in this case as I'm looking to reduce the current flow in the coil and weaken the flipper power.
Hope that makes sense.
