The non Ghosting bulbs, CT, PBB, PBL, and mine all perform the same in Spiderman.
They will eliminate ghosting, and reduce the flicker somewhat. In my Spiderman, and testing all, I found this true.
I also, tested the same non ghosting in another friends Spiderman, and his results were better.
One of the bulbs we had flicker, was NOT flickering on his game. Meaning more a socket/game issue here then the bulb.
The Superflux Piranha, No-Flix, from Pinball Center, Optix from Comet, and also at Pinballdecals, was my next personal test, and it improved even further, but still not "perfect".
If one is sensitive to this or demands perfection in life, an OCD board will fix this.
Bulbs by themselves, have different levels of help, and for some, it is good enough...
for others it isnt.
And just for the fun of it guys...most of the bulbs are 90% the same.
Games, Insert Wear, Ambient lighting, your eyes, sockets, power boards, home power.....
All these affect your results. After similar threads over and over...guys sometimes its something other then the bulbs,
but we bring the battle back as if it is the bulbs.
A higher cycle rate by the OCD board is the only way to 100% change the results....Otherwise, be happy with non ghosting, or Super-Flux...Regardless of Who's bulbs...please lets stop banging that drum....Give your business to whom you want for the reasons you want, not because one person yells loader then the other that so and so bulbs are the best..
Kumbaya
Art
