I received my sideblades for my Ghostbusters and installed them across the weekend. I watched a couple of videos, read a bit on pinside and elected to use the two drops of dishwashing liquid in a spray bottle of water as I didnt want to remove the playfield. I can report its a great method. Peel the backing off, spray the sticky side of the blade (one at a time) with slightly soapy solution, you can then slot the blade between the vertical playfield and cabinet easily and then position and reposition with no dramas until its perfect!
07B34273-B10F-43A3-8441-41184E2F8702 (resized).jpeg8AF60F86-019B-4D26-B732-2BAE82CD77E5 (resized).jpeg9746127F-3A24-43E4-9E42-972FE31C11C7 (resized).jpegB71EF88B-FE88-4701-BB1A-789CAE1ED42D (resized).jpeg
