(Topic ID: 127971)
Stern SDU 100 HV issue
By 80spit
8 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by barakandl
    #1 8 years ago
    I am trying to bring back a SDU 100, HV section will only go up to 120volts. good 220 going in. I had put in all 3 new transistors. Caps look new. diodes checked out, put another VR in, it still hangs tight at 120v andwon't light the displays. should I just replace all the HV section? kind of stuck at the Moment, don't really need it but would like to have it as a spare.
    #2 8 years ago
    1. Is it adjustable ?
    2. Did you put in the correct Zener diode the correct way ?
    3. Do you have a burnt resistor ?
    * I would do comparison resistance checks against the good board and see if you find a
    difference to locate a bad part.
    John
    #3 8 years ago
    In my XP, low but adjustable high voltage is usually the zener diode.
    Since you replaced that, how about c26 filter cap?
    #4 8 years ago
    Quoted from barakandl:
    I only pulled one end of the Diodes to check them, I will change the zener out and see what happens.
    the VR does adjust the voltage just max's out at 120volts
    #5 8 years ago
    With the game power up, measure vdc on each side of vr1 diode. I think it is 110v zener.
    #6 8 years ago
    Got it, Andrew, you were right, Sure do appreciate your help, temporarily stole the VR1 out of a working board and got this board working again! got some 1N5275's on order, Sure is great to
    see a board come alive again.
    #7 8 years ago
    No prob. That is the only failure mode of VR1 in that circuit i have seen. Comes up often enough i put in a new 1w rated zener when I rebuild these driver boards.
    This page was printed from https://pinside.com/pinball/forum/topic/stern-sdu-100-hv-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
