I have a Hot Hand which the SB 100 sound board works perfectly for 45 min to an hour then suddenly mutes the amps.
I can turn it off, wait 15 minutes and all is fine again. Then just repeats muting after and hour being on.
For some reason pin 1 on the LM380's is going low.
Does anyone have any idea what could cause this. I have recapped the board and installed a new 2n3904 at Q6 and 2 new LM380 amps.
It is a revision C1 board and its muting ciircuit is different than schematic. It does not use pin 25 from cpu reset signal.
I can't seem to find a up to date schematic for the C1 muting circuit.
