It possibly could be that Stern got an order of parts from its hardware supplier that were/are defective from the supplier in that the chemical conversion coating, or zinc plating, or cadmium plating was not performed to specifications.
Three or four years ago, Boeing Aircraft in Seattle received a large batch of nut plates that were not treated properly (supplier error) and started corroding after installation in the airplane. Hundreds, if not thousands of nut plates are riveted all over inside and airplane structure and are used to attach all kinds of parts. And some of them are buried deep inside. Boeing had several planes in the factory that had to have all of the defective nut plates removed and replaced with new nut plates that were proper.
THe best way I could relate this to pinball is if you had to crawl inside your cabinet and replace the back leg bolt brackets without removing your play field.
It was costly for Boeing and the supplier. The supplier was permanently banned from doing business in the future.
For Stern, this would be a cosmetic issue and not a safety issue. My money is on Stern's supplier sending out junk and Stern, and ultimately the retail customer takes the hit.
This is a nut plate.
