New! Dark mode!
(Topic ID: 187740)
Stern rom update reboot time? SuperHerg Strikes Again!!!
By MrWizzo
  • 29 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by MrWizzo
#1 3 years ago
Updated Tron rom, and it has been in rebooting for at least forty minutes. Normal?
Dan
#3 3 years ago
Didn't think so. Thanks Lloyd. Any suggestions?
Dan
#4 3 years ago
It's a SAM System. So things I'd consider would be smaller memory stick, different memory stick, fresh download.
And refresh my memory with the directions to be sure I didn't miss something.
#5 3 years ago
Will try and report back.
#6 3 years ago
Neither stick is being read by game although they both work fine on my laptop. Odd as one of them was read on the original download attempt.
All files were deleted on both drives before downloading.
#7 3 years ago
Same brand ? Only thing I can think of is try a different brand.
#8 3 years ago
Different brands. Unzipped the files on both, but didn't help. Yeah, will pick up a new one tomorrow. Thx.
#9 3 years ago
Quoted from MrWizzo:
If that fails, I'd give Stern tech support a call on what next.
#10 3 years ago
Quoted from LTG:
It's a SAM System. So things I'd consider would be smaller memory stick, different memory stick.
What size sticks did you try already? Have you used these in the past to update code?
#11 3 years ago
One is too small in capacity about 2.5G, so that makes sense.
The other has been used twice, on IM successfully and this TRON seemingly successfully, but the game was stuck in "rebooting." After about two hours, I turned the game off.
It is about 9G in capacity. Checked that is FAT32. I have scanned it for disk errors and reformatted it. Ejected it properly. Tried it with the file compressed and decompressed.
Cannot think of anything else to do with it. Will get a new one today and give Chazz a call tomorrow regardless.
Weird.
#12 3 years ago
I would definitely try another thumb drive.
#13 3 years ago
Yep, for sure. I even tried changing the allocation sizes on the one drive to see if that would make a difference. No soup for me!
The other drive wan't too small. Wrong about that. Wouldn't format to FAT32. Tried it again but to no avail.
#14 3 years ago
New stick; same results.
#15 3 years ago
Weird.
2.5G too small ????
Typical SAM update files are no bigger than 100MB.
Try an older, smaller drive. I use a 1Gig drive that has never failed to update multiple games.
#16 3 years ago
Read through the thread.
No old smaller drive on hand.
#17 3 years ago
I have read through the thread. Try another drive. Borrow, steal or purchase one but I think the older, smaller capacity drives work much better for updating Stern SAM games.
#18 3 years ago
Yeah, the 2.5G estimate was in error. Realized that after I saw the size of the file. DOH!
The new one didn't work, and I have a neighbor deleting content on a older smaller USB drive for me to try.
Should have it shortly. Thanks for the follow up. Buying didnt work. Borrowing may not. Leaves me only stealing at that point!
#19 3 years ago
Neighbor's 4G no good either. File not found. OY!!
#20 3 years ago
Maybe you have a bad download of the code ? Is the unzipped file a .BIN file about 31.5MB ?
#21 3 years ago
Have you ever updated Tron before ?
Whether you have or not, I'd call Stern tech support. Somethings wrong.
#22 3 years ago
Neighbor found a 2G also, which did not work also. Need to start calling Kurt "State Farm."
The BIN file is the size you described, and I am making sure I open the stern page for the code anew each time I download.
Never updated the game before. It had 1.7 and am trying to upload 1.74, I think it is. The only other stern update I did was with IM when I had it, and that went flawlessly.
Will be calling Chazz at Stern tomorrow and will report back.
Thanks for the input.
#24 3 years ago
I definitely suspect a board issue then. I started thinking that after all your other efforts failed.
#25 3 years ago
Yep, set eight to on.
Board it most likely is.
#26 3 years ago
I have a known working thumb drive that should already have the latest Tron update on it. If the game is at your house, I could stop by. It sounds like you have probably already covered all bases on the drive, though. I have heard of a couple of cases where the board had a problem, but that is very rare.
#27 3 years ago
Hal,
Thanks for the offer. Let me see what I can accomplish by calling Stern tech support first. Either way it would be great to see you. It has been a while.
I'll give you a call later today.
Dan
#28 3 years ago
I pulled the "pinball boot V 3.1" prom on the board and reseated it, but no luck. Wondering if somehow it got corrupted on the initial download and two-hour long rebooting sequence. Game fired up and played fine with no issues prior to attempting the update.
Got through to tech support. A new tech David was helpful and is sending me out a new boot prom to see if that is the issue.
#29 3 years ago
Herg brought his 1G stick with Tron 1.74 and it loaded with no problem.
He traced the target bank motor wiring to a black with orange wire. It went up into the backbox into a three prong connector as the only wire in it. It is close to a three pin connector with yellow and purple wires. I was reluctant to connect them originally since the colors didn't match after I reassembled the game, but he found a picture that suggested they went together, and we connected them. Bank motor now back in order.
I wounder if the LE has different wiring there reflecting upgraded features.
Thanks to Hal for reaching out. If everyone in the world was like Herg, it would be a much, much better place.
Dan
€ 95.00
FlipperLED
$ 54.99
$ 499.95
Pin Stadium Pinball Mods
Professor Pinball
Lighting - Backbox
Mount Airy, MD
