(Topic ID: 241505)
Stern Rolling Stones Insane Airballs and Ramp Rejects
By CrazyLevi
2 years ago
  • 25 posts
  • 10 Pinsiders participating
  • Latest reply 2 years ago by akm
#1 2 years ago
Just picked up a RS, and it's insane.
It is in very clean HUO condition and I cleaned the and playfield and replaced a flipper transistor before playing. Almost every single shot forehand or backhand to the right ramp will launch either to the side or into the (very low) plastic tongue, and reject.
I turned the coil power to soft and it helped a tiny little bit. Game was very steep but I lowered it a bit, no difference.
Is there a way to raise the Tongue? Doesn't really look like it. Is this just a side-effect of a newly novused playfield and clean game?
Shots were also rejecting from the Charlie shot on the left, the plastic was a little low (I shimmied it higher) and it is getting air off the Mick track I suppose. It's a bit better now but ball still going everywhere and rejecting. Only clean shots on the game now are the orbits and the center ramp.
I don't think I've ever owned a game that was this fast and airball crazy. It reminds me of an F-14 with ski ramp bonus inserts.
Any advice or help appreciated. I've played this game many times (other machines) and it's usually a pretty smooth flowing game, but this is a mess right now.
Ill post some pics tomorrow maybe someone will see something.
#2 2 years ago
Are all the coils more powerful than they should be ? Got me wondering if the game is wired for 100AC and you plugged it into 120AC ?
#3 2 years ago
Quoted from LTG:
Interesting. That info would be printed on back of the game and at the transformer?
#4 2 years ago
put the high power flipper coils in my lotr a few years back and that is how it played. had to go to med power coils.
#5 2 years ago
Quoted from CrazyLevi:
Unless someone changed it.
#6 2 years ago
I believe this was addressed with "Service Bulletin #66".
It recommended standing 30 ft upwind and pointing the flame thrower at the coin door.
Sorry Levi. Just kidding. Kind of.
#7 2 years ago
Quoted from LTG:
This seems extremely unlikely. It’s a HUO machine domestic build.
The tilt Bob wasn’t even installed and the manual was still in the sealed bag.
#8 2 years ago
Stern Rolling Stones is the fastest game I own(especially when powerball is in play). I honestly think Rolling Stones is the fastest game currently out there. I have zero issues with airballs? Great game-I love mine(Mick on a stick ROCKS!). May try and switch out flipper rubbers(may be too high?) I use super bands on all of my pins and I feel they help control the ball better.
#9 2 years ago
Quoted from pinmister:
I'm a huge fan too - this game gets a bad rep but there do seem to be quite a few of us who really enjoy it.
Mine is fast and furious, rarely get any airballs ... if I do they seem to be from a sling shot. Occasionally it may reject at the Lips ramp.
#10 2 years ago
Ok here’s the wiring and Diagram.
It indeed has a 115 jumper installed. But that’s correct? Or not?
I’d love to dial it back to 110 if it’s incorrect. I’m not really understanding this.
45E17536-96EC-4E97-85AA-F861C208A18D (resized).jpeg8054153E-A02C-49E6-B864-3A53F43BBD49 (resized).jpeg91836761-EB3F-4C09-830D-320D7B39580B (resized).jpeg
#11 2 years ago
What is your wall outlet voltage ? If 115AC that is good. If the wall outlet is 120AC, that is why things are stronger.
#12 2 years ago
Quoted from LTG:
I’ll check it out.
Same place I’ve been for 10 years and my other games aren’t this ridiculous
#13 2 years ago
OK...
so made game steeper. Also shoved some cardboard and a little painters tape under the tongue to raise it.
Did the same thing (well a post rubber) under the plastic above Rock Star/Charlie shot.
Not pretty, but I'm happy to say game is now playable. Actually started Rock Star for first time, and got Encore for the first time ever also.
I'm hoping the game just settles down a bit. It's basically brand new. I certainly won't be novusing the playfield again any time soon.
#14 2 years ago
Airballs are bound to happen once in a while (particularly with the Mick on a stick or the Rockstar standup on the left ramp), but it generally shouldn't be happening on normal ramp shots. Things like the ramps, orbits, records shot and side targets should be pretty smooth on this game.
Interestingly though on my LE, I did notice more airballs than on the Pro I owned previously. I just dealt with it (it wasn't as consistent as it sounds like it is for you), but I did notice the game flipped and felt totally different from the Pro. I'm not sure what it is, but that could be part of it.
#15 2 years ago
I honestly think the issue is that the mick track is a little "off" in that the high lip is a little lower than the lower edge. Might try sanding the high edge a little bit.
#16 2 years ago
I had the same issue with my Roadshow after cleaning. Crazy fast balls flying everywhere and just waiting to shatter plastics. I ended up swapping my flipper coils out for weaker ones. I went one step down and it is perfect now. I would do that first before irreversibly changing (sanding down) the play field.
#17 2 years ago
Quoted from Marten:
Yeah I've got some lower power coils on the way and will try that out. The game is settling down a bit as I play it more.
#18 2 years ago
A game I really miss, very underrated, and hard as hell.
It’s anything but “just shooting the middle ramp” the shots are spread out and it’s a lot fun. Sounds like you cleaned it too good, which can really send balls flying until it gets a little worn down.
#19 2 years ago
Yes I agree this game is much better than advertised. I don't know who did the main rules but you can tell that there is a bit of a Lyman touch; the modes are well thought out and fun to pursue, and the stackability keeps things interesting. Really enjoying the game.
#20 2 years ago
Yep - its fast, furious fun with a decent ruleset. Challenging modes and the Multiballs have some nice rules to work thru. Unfortunately when it came out most people took one look at Mick on his Stick, the stripped back playfield and decided they weren't gonna get no satisfaction Proves very popular with visitors.
#21 2 years ago
Quoted from Ive:
People never get tired of complaining.
It's a great looking game. Doesn't look cheap to me. The molded 3D tongue is a nice touch.
#22 2 years ago
Software Lonnie and Lyman.
#23 2 years ago
Agree - they missed a trick not having the tongue interact with the ball in some way though, moving up/down or whatever. Oh well. It's very interesting reading the design process for the game in Pinball Journal #146 . It changed a lot ! from the initial ideas.
#24 2 years ago
Quoted from Ive:
Lol it interacts plenty with the ball on mine!
Aiiirrball!
#25 2 years ago
The stackability on this game is one of my favorite aspects of it, and what's nice is it's all relatively easy stuff to do--you're not spending ages getting it all set up. For instance, start records, then start licks, then start multiball. Or if you want to get fancier, get a Super Combo ready on the center ramp and have that going on top of the others during the multiball. It's fun stuff. I suppose my only disappointment is not being able to stack multiballs. The wizard mode (Encore Multiball) is extremely tough to get to because you can't stack Album with Rockstar (unlike say, Avatar or Iron Man, where their two main multiballs can be stacked, making completion much easier).
I always assumed Lyman worked on the game a bit as some rules are similar to what he's done on previous games. For instance, a five way combo to start Super Combos, or the Records mini wizard mode basically being Total Annihilation from AFM, and Rockstar Multiball being War Machine from Iron Man.
