Quoted from Jvspin:So, you're saying they are no longer "coin-op" games so it's okay to complain about NIB problems?
Maybe that was PPP's strategy with the missing coin mechs all along!
I would like to add that some of you seem to have purchased Stern sarcasm detectors please have them shopped at the the Pinfactory2000.
Quoted from markmon:When I buy a game nib or used, it goes into my workshop not my house.
Yeah - I do the same thing.
Quoted from Darscot:I would like to add that some of you seem to have purchased Stern sarcasm detectors please have them shopped at the the Pinfactory2000.
Hey! Our detectors are for commercial use only. They are $8k retail and may or not work out of the box. (But the store you buy them at sells soldering guns so...figure it out, that's part of the fun!)
Quoted from lowepg:Maybe that was PPP's strategy with the missing coin mechs all along!
I think that would be a poor strategy because it appears as long as you can claim your product is "commercial coin-op" you can probably save money by eliminating the QC and test departments.
Once I get my hands on 'em there is nothing to complain about.
Quoted from Pinfactory2000:These aren't consumer products. These are vending machines (think washing machines). Made for commercial use only.
Yep. This.
Quoted from Darscot:Is this the mentality with all products you purchase, or do you just accept the quality is so dreadful at Stern? You do realize it's guys like you that are doing the most damage. Your average consumer needs a private shop and be willing to put a few hours labour in if he plunks down several grand on a NIB. That sound like a solid business model.
In Australia, the distributor removes all new pins from boxes and checks them over, updates the code, plays them,adjustments if needed and re boxes them, then sends them to their customers.
My distributor pulls out NIB pins and check for damage and do electrical cert and general check.
Quoted from Kiwipinhead:In Australia, the distributor removes all new pins from boxes and checks them over, updates the code, plays them,adjustments if needed and re boxes them, then sends them to their customers.
Wow! Now that's service.
Yep, ours in Perth does it too. Unless you are too anal and want it untouched by humans.
The distributors in Australia were getting so many pins with quality issues from Stern they had no choice.
Quoted from Toads:While I'm on the subject, does everybody change out the Stern balls when they receive a new pin?
I pull them out of the bag and clean them with window cleaner before installing them. That makes them shiny like most aftermarket balls.
I examine them closely because they are almost always more pitted than new balls... if any doubt they get replaced.
Quoted from vid1900:Once I get my hands on 'em there is nothing to complain about.
Always.
Stern's balls are only OK, the "super shiny" ones are excellent.
My new machines get new ooohhh_shiiiiny balls.
I replace my balls after a few hundred plays.
I have people on craigslist buy my used balls for $1 each.
My playfields look perfect.
Quoted from chuckwurt:What about switching out the stock rubbers that Stern ships in their games? Anyone do that?
I switch all my games to clear now....
Quoted from Pinfactory2000:Ah ok. I thought your point was that the number of issues to the number of pins being produced wasn't that high...
Anyway. Thank you for bearing with the lesser brained pinsiders like me!
Point----->
My Head----->
Regardless, piling on if you don't have legitimate issues is not ok. I agree.
Additionally, I'm optimistic stern will work through my (and other pinheads) issues when they buy NIB. below are pics of missing bolts (all 4 that attach the playfield back were missing) and playfield buffing issue (one of 3-4 areas where clearcoat was buffed through. (Let the 'get over it and play pinball comments commence!!)
Curious to know if the issue with your playfield clearcoat was resolved or did you fix it your self? Opened my machine yesterday and noticed several areas on my playfiled also where the clear coat was "dull". tried to polish it up with novus 1 and 2, and a few different waxes, which did absolutely nothing?!?! Has anyone else had or have these dull areas on their new Sterns? How can these areas be fixed to resemble the rest of the playfield clearcoat?
Quoted from Off2War:Curious to know if the issue with your playfield clearcoat was resolved or did you fix it your self? Opened my machine yesterday and noticed several areas on my playfiled also where the clear coat was "dull". tried to polish it up with novus 1 and 2, and a few different waxes, which did absolutely nothing?!?! Has anyone else had or have these dull areas on their new Sterns? How can these areas be fixed to resemble the rest of the playfield clearcoat?
Throw the novus in the garbage for starters and use a basic cleaner like simple green and some regular old wax not a plastics cleaners
Quoted from jrivelli:Throw the novus in the garbage for starters and use a basic cleaner like simple green and some regular old wax not a plastics cleaners
What type of wax do you recommend? I have used pure carnauba wax with no improvement whatsoever....
Quoted from Off2War:What type of wax do you recommend? I have used pure carnauba wax with no improvement whatsoever....
If the clear was extra thin, using novus 2 (a harsh running compound) may have actually done it in for good. Otherwise I would treat it like a car. Wax it with a good carnuba.
I've had minor issues with my Stern's but like most have said, nothing ever breaks and the issues I have........Patrick or Chaz always take care of me.
Quoted from markmon:If the clear was extra thin, using novus 2 (a harsh running compound) may have actually done it in for good. Otherwise I would treat it like a car. Wax it with a good carnuba.
What he said, you may need to be rubbing and polishing with a wax only for a while. Novus 2 may have harmed it further
no. there is nothing thats going to take a dull area of the clearcoat and fix it...At least, not one I'm aware of. I used some cleaner (treasure cove) and then Carauba wax (mothers I believe, I'd have to check) to shine it up the best I could (really didn't change anything frankly).
Just had to swallow the fact that my playfield with cosmetic imperfections (and pieces hanging off it)
And remember...Its mostly your fault.
*shrug*
Quoted from o-din:Pinball machines are designed to make money. Is anybody finding quality issues that are preventing them from doing that?
Yes, they don't last, they fall apart much faster and the PFs wear faster.
Quoted from zr11990:Yes, they don't last, they fall apart much faster and the PFs wear faster.
How's that?
Quoted from zr11990:Watch how fast they turn to crap in the wild.
Not sure what you're talking about here. The GoT I just got has the thickest clear coat I've ever seen in a new game. I've also gotten several games from route ops through here and some of the new sterns clean up like they're brand new.
I'm not seeing any issues out of the ordinary on Sterns in the wild. Everything I see I also see on the William's/Bally games. My "route" experience is limited though with games at pinballz for the most part. Most common thing I see is a chipped or cracked ramp and flaky switches. I don't think I've seen one with major PF wear like the paint being worn down to the wood. Just some wear in holes for VUK's.
Quoted from 85vett:I don't think I've seen one with major PF wear like the paint being worn down to the wood.
Cue faked picture of Star Trek playfield in .......3.....2......1......
Quoted from jkashani:BUMP! Anything from BM 66 and on is lackluster...Happy Holidays
What a stupid comment. Merry New Year
Quoted from Hazoff:What a stupid comment. Merry New Year
Lmao...
Get drunk and laid MotherF***ers! WHEW!
0BB5DDCC-53A2-4C6E-91D6-C3730FCD3418.gifQuoted from underlord:Get drunk and laid MotherF***ers! WHEW!
That wouldn't change my post, actually it would be much worse. But it still a good idea and if you knew what I was going do tonite last thing u would think is this guy needs to relax, relaxation is for the very old and dead. Merry Xmas Underlord, typing that makes me happy.
Satan_claus (resized).jpgQuoted from Hazoff:That wouldn't change my post, actually it would be much worse. But it still a good idea and if you knew what I was going do tonite last thing u would think is this guy needs to relax, relaxation is for the very old and dead. Merry Xmas Underlord, typing that makes me happy. [quoted image]
Back atcha Bubba.
Quoted from underlord:Lmao...
Get drunk and laid MotherF***ers! WHEW! [quoted image]
Not LAMO bumping this 3 yr old thread is acting a fool or tool take your pick
My 8 year old daughter just printed out your picture of Santa and hung it in her room.
Yeah. Iron Maiden. What a dud.
(sarcasm)
Guess who's been into the nog this season???
Quoted from JY64:Not LAMO bumping this 3 yr old thread is acting a fool or tool take your pick
Ok Krampus. Have another drink. Or stop drinking and posting. Have YOUR pick.
And I didn’t bump the thread.
Pretty funny reading this old thread. Gotta hand it to Stern they have put serious effort into quality and consistency over the last 3 years. They are in a way better place as far as consumer confidence, now if they could just give me a theme.
Quoted from Darscot:Pretty funny reading this old thread. Gotta hand it to Stern they have put serious effort into quality and consistency over the last 3 years. They are in a way better place as far as consumer confidence, now if they could just give me a theme.
I’m not convinced. When I hear that a cpu board goes bad and a customer has to spend $600 for a new one rather than be able to fix it, that’s a downgrade in quality.
Quoted from underlord:Ok Krampus. Have another drink. Or stop drinking and posting. Have YOUR pick.
I know you did not bump the thread you did give Hazoff a hard time for scolding the fool that did bump this fool thread after 3 yr
Quoted from Lermods:I’m not convinced. When I hear that a cpu board goes bad and a customer has to spend $600 for a new one rather than be able to fix it, that’s a downgrade in quality.
Sounds like a win from Stern's view point.
OK,my GB/Pre lasted a week and node board #8 blew! My B66 LE turntable was completely broken in box,no QC there!!Also,because of Sterns drop targets,the left "D" on my DP/LE was not resetting.and had to be fixed! So I think there is validity to what is being said here!! Happy New year all!!!
Not saying they are perfect by any means but three years ago it was daily open hostility. Ghosting inserts, chipping clear coat, cabinet decals, splitting corners and the node board issues that you are mentioning. I agree the board design is not ideal for the industry but its comparable to modern electronics. Board repair is pretty rare these days, it’s all just discard and replace. Board failure doesn’t seem to be as widespread as the list of other issues they had. I think it’s fair to say they have been making efforts to improve. Man Ghostbusters alone had like every quality issue, plus bending guides and faulty slimers, it was hard to keep track of all the problems it had.
Quoted from hawkmoon:OK,my GB/Pre lasted a week and node board #8 blew! My B66 LE turntable was completely broken in box,no QC there!!Also,because of Sterns drop targets,the left "D" on my DP/LE was not resetting.and had to be fixed! So I think there is validity to what is being said here!! Happy New year all!!!
Yet you buy a Deadpool LE why should they change
Quoted from JY64:I know you did not bump the thread you did give Hazoff a hard time for scolding the fool that did bump this fool thread after 3 yr
Would you rather he started a brand new thread when there was already one?
This page was printed from https://pinside.com/pinball/forum/topic/stern-quality-going-down-the-drain/page/6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
