Gang:
I am the current owner of the "Smoking Hot" Playboy as featured in the following thread:
It has a nagging issue which has me puzzled.
When I received the game it was resetting at random to the point which a single ball could not be completed. I started to methodically go through molex connectors and found several shorts where insulation had melted thus causing wires to touch each other. The boards were not securely fastened to the ground plate and were literally not touching it in places, so was definitely missing ground points. There were several connectors with wires in the wrong slots and hitting the wrong pins. All the aforementioned issues have been cleaned up and the game is error free. Now, it will play a complete game UNTIL the auto launch engages. Whether it be for a ball save or for multiball, as soon as that coil (#2) fires, the game reboots. Firing the coil in test achieves the same result. The coil and diode both check out good.
The boards were new and installed shortly before I took ownership and there is no evidence of any components blowing on the board. I have not pulled them out and tested individual components, but certainly can, if we suspect a culprit there.
All voltages at test points on the board are within acceptable thresholds.
Photos attached of relevant pages in the manual.
Thanks for your help!
