Quoted from pinballslave:I can try it, but will have to do it by hand at the moment... if anyone has easy access to the game, would be cool if you could verify how the drop screen tests and centerfold tests play out on your healthy game... I'm not familiar with this game, so I don't even know how to start centerfold multiball or to get the drop screen to drop...
From the manual: Centerfold test:
Selecting the"CF" Icon will bring up the CENTERFOLD MOTOR TEST MENU. This test is provided to allow a method of testing the Centerfold Motor (Open/Close) (Q32) in conjunction with the Motor Relay Board (On/Off) (Q31) and the Centerfold (Motor) Switches (Sw. 43 & Sw. 44). Upon entering the test, the display will indicate the status of the Relay Board (either STOPPED or OPENING) and indicated the status of either Switch (the "RUN" Mini-Icon will be flashing). Select either the "RUN" or "PULSE" Mini-Icons. Activating the "RUN" Mini-Icon will cycle the motor until the Centerfold Assembly is completely OPEN or CLOSED. Activating the "PULSE" Mini-Icon will pulse the motor. Watch the display, as the Centerfold OPENS or CLOSES, the switches will close (the . box will turn solid ).
!& &% 90 !407 39074. $9.
