Can some kind pinhead post a few up close pics of the two small opto boards and the surrounding wiring on their RBION? I just picked one up a few days ago (along with a LOTR) and it's my first Stern game that I need to troubleshoot. So I understand that the optos work differently than BW and I've read Sterns service bulletin 67 on their optos but I am stuck.
Here's the deal. The shrunken head, idol and super jackpot optos are all not working. In switch test most they all show as closed. From what I read they should all read open. The idol opto transmitter is on and red, but not the other two transmitters. I get 5V at all the transmitter 2 pin sets. I have swapped in new LEDs in the idol to test, but that didn't change anything. Didn't think it would since the switch is reading as closed anyway and it sure would be odd that all of them are bad.
When I pull the main connector from the opto board the switches will read as open and then they will register a hit and close and stay closed when I plug it back in. All the three optos are on the same column in the SM, but the other switches in that column work fine. Could I have a bad transistor at Q3? How do I test that? Could I have a ground short somewhere, even though the non opto switches in that column work fine?
One other question. When replacing the opto LEDs, does the positive (the long side, right?) go in the K or A side of the opto board?
Thanks in advance for any help!
