For those interested, here's the readme file of the two most recent updates.
V1.20 - April 10, 2014
- fixed mystery award.
- fixed top lanes display effect (text off screen).
- upgrade hurryup/multiball start not available if drift or stampede is ready.
- fixed orbit upost logic when races and upgrade hurryup are running at the same time.
- the "Upgrade Hurry-Up Start" presentation now precedes the "Gears Multiball Start" presentation.
- added logic to allow rally and stunt races to be paused.
- Added pause code logic for timer in road course, and also pause code for the light shows and daisy speech in drag race
so it pauses the timer when mustang multiball is running.
- removed the final two shots once you are in 2nd place in road course, just the scoop is lit to finish the mode.
- Races do not inhibit up-post if upgrade hurryup is running.
- Tweaked the "race is started but not completed" lamp blinking pattern.
- added upgrade hurryup as the first upgrade tier award.
- now top lanes can be moved with the flippers.
- top lanes reset between balls
- races are not allowed to start if an upgrade mode/multiball is ready to start.
- Added new drag race multiball dots to gears multiball start.
- Added new daisy diesel speech to drag race mode, and fixed the timer so you can hear the background speech.
- Added Mabel speech to road course jackpot display effect
- Added new dots to road course end to get rid of daisy holding trophy when you win.
- Tweaked scoring in rally race.
- Fixed rally race always putting user into Driving straight after they drain.
- Fixed rally race lights in race select.
- Fixed rally race not keeping track of #shots made after ball drain.
- Police Pursuit scoring
1. 6.5M if you make it to the chase.
2. 15.7M if you finish everything.
- Fixed lamp effect not being killed properly
- Added new lamp effects to: a) Gears multiball start b) Orbit shots in rally/stunt
- Added new gears target hit sounds
- Added translations to coil, lamp, message, switch tables.
- added a background display effect that shows the race name and all player scores (and ball/credits if there is space).
This display effect is used as the background display effect for races in the following case:
num players>1 && ball is in shooter groove. The reason for this is so that in a multiplayer game,
the players know which player is up.
- Race lights - if a race is "started" but not yet "completed", it will blink 28ms on, 4 ms off.
- added new race course speech.
- Added sound effects to hitting the gears drop targets.
- Added rally race turn callouts.
- Made shifting to higher gears easier. (gear 5 and 6 are now easier to achieve)
- Allow player to flipper blowoff gears multiball intro.
- cruisin now has 2 levels. The second level requires the player to make 4 roving shots.
- Crusin display now shows 2X awards, cruisin base scores are reset between sessions.
- spinner moves the top lanes.
- pause races during Mustang Multiball.
- Added new speech to drift.
- Added new dots to drift.
- Upgrades are awarded immediately rather than collected at the scoop.
- Upgrade Tier awards are awarded immediately upon completing all 7 upgrades.
- added Silverball Stampede Ready, Silverball Stampede music.
- Added background music for silverball stampede and drift ready/intro.
- Fixed the following music issues
1. Race Select restarts every time flipper button is pressed
2. Music turned off when resuming a race and entering test mode.
- Bonus music: kill bonus music when bonus display effect terminates.
- fixed demo race bug.
V1.13 - April 3, 2014
- released 1.13 code for NY Auto Show, Empire State Building, and regional shows.
- This release is for Demo Race default ON.
- Fixed bugs with road course restarting/continuing.
- Fixed text in the drag race intro for the demo mode.
- Demo race multiball now 4 ball instead of 6 ball.
- added demo race requirements (No replay, no match, no high score, free play 1 ball game).
- Do not start Race Select if Mustang Multiball is ready.
- Do not blink "NEW CAR" when in Race Select.
- Fixed two sound effects whose names were reversed.
- Gears multiball recognizes when demo race is active and adjusts rules and scoring accordingly.
- Demo race adjustment now selectable.
- In demo race, no mustang letters can be collected, no upgrade multiball can be started, and no mustang multiball can be started.
- If AD_DEMO_RACE is YES, play DEMO RACE music and disable Race Select (it was starting from the scoop).
- added upgrade hurryup logic.
- Changed the shift lights so that they represent the drag race when in the drag race mode, the lights had been showing the current gears level
- Used drag race mode end dots, in road course mode end to let you know your place at the end of the race
- Revamped the road course part B, so that you have to get 1st place to complete the mode. Changed the way you earn bonus points for 1st place.
- Added light show for road course end with you in 1st
- Added other racers to road course start display effect
- new match effect artwork added (to allow blinking of matched numbers)
- changed match display effect timing.
- Fixed number of jackpots needed for super jackpot to light
- Bumped up gears drop target scores
- added/changed sounds in match effect
- added art to mystery, mystery lit display effects.
- fixed a right orbit bug caused by drift race, i.e. it caused balls to go into the pop bumpers even if drift race was not running.
- added toolbox art.
- added Tanner Speech.
- added cruisin award sounds.
- added return lane sounds.
- added tilt/warning sounds.
- Modified Drift race rules.
- Added game timer pauses (Drift).
- Added some additional movement to the cars in the drag race background to show them jockeying for position
- Changed the intro Display Effect on ball 2 and 3 for the drag race mode.
Now, if you drain on drag race before reaching MB, it will show daisy diesel instead of showing the cars taking off again. Added more drag speech.
- Changed the opening text from the “champ vs 1970 mach I” to “Daisy diesel vs 1970 mach I”
- Added confetti dots to road course end if you get 1st place, and also cheering sound effect.
- Fixed a bug when tilting in road course that gave a "congratulations 00" message for completing the race.
- Added rules to mode intros with a screen flip, only showed the first time you play.
