My friend acquired a Stern Meteor and the sound stopped working. Game plays otherwise. Game has a Sterns SB-200 board. The person we purchased had a similar problem (no sound) but got it working by apparently removing and reconnecting some connectors. When we got it home, it played fine for a day but then the sound stopped. We checked the voltages on the rectifier board, solenoid board and they checked out o.k. Tested voltages on sound board test points and found all tested o.k., except the 5 volts only reading a little over one volt. I cleaned all header pins and reflowed all the pins. All the traces including the 5v trace from the ribbon cable pin to the 5 volt test point are good and have continuity. I am starting to suspect the ribbon cables between the MPU and sound board. Is there something else we should check on the SB or the MPU? Need to make sure we are getting 5 volts out of the MPU and that 5 volts is getting to the sound board. THX for any help.
