(Topic ID: 247534)
Stern Meteor Issue
By dpapclare
  • 11 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by dpapclare
  • Meteor Stern Electronics, 1979
#1 4 years ago
So I just got my Meteor up and running again and it now seems to have a strange issue where when you hit either flipper button (right flipper button more than the left), a slingshot with fire or the pop bumper will fire. With the right flipper, the upper one fires but will drop after the coil firing (happens intermittently). Not sure how to explain it better, anyone know where to start with this or has seen it before?
#2 4 years ago
I think you are describing the noise from the coil turning off getting into the switch matrix. It is unavoidable to a certain extent and normally does not score points when it happens.
If it really bugs you can you try and move the flipper wires away from being bundled in with switch wires and shield it some how, but I'd just ignore it unless it is happening really often and scoring points.
#3 4 years ago
Quoted from barakandl:
It's not scoring points but it happens enough that it is effecting the game play. Especially when the upper flipper goes up and immediately goes back down as if it's the hold isn't working
#4 4 years ago
Quoted from dpapclare:
Flipper button and EOS switches that are pitted, make large arcs, or cause flipper fluttering are probably going to exacerbate the issue.
#5 4 years ago
Replace the switch caps on the slings and pop bumper and make sure your flipper coil diodes are good.
#6 4 years ago
Does this happen nearly every time you flip the flippers? You sure the slingshot and pop bumper switches are gapped enough? What happens if you hit the playfield with your fist, does the slingshot/pop bumper activate from vibration?
#7 4 years ago
Quoted from Quench:
I checked the gaps and they looked good.
#8 4 years ago
This is kind of what I was thinking may be the issue, I'll take a peak at it this afternoon and see what they look like!
#9 4 years ago
Quoted from slochar:
I'll check these out this afternoon!
#10 4 years ago
This is exactly the problem. They look terrible and actually managed to cause a reset if the game when I hit the right flipper fast enough hahahaha
#11 4 years ago
You were correct! By the way, the new board is awesome and works great
$ 44.00
PinballReplacementParts
$ 100.00
The Flipper Room
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
$ 3.00
$ 29.00
RoyGBev Pinball
Slipstream Mod Shop
Beehive Pinball Co.
$ 149.95
Allteksystems
Troxel Repair
Middletown, OH
$ 169.00
This page was printed from https://pinside.com/pinball/forum/topic/stern-meteor-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
