(Topic ID: 306097)
Stern Meteor F4 fuse flippers
By Lambecka
1 year ago
  • 66 posts
  • 10 Pinsiders participating
  • Latest reply 1 year ago by Lambecka
    There are 66 posts in this topic. You are on page 1 of 2.
    #1 1 year ago
    Stern Meteor
    After restauration MPU and replacing rectifier board, starting up the machine and everything looks fine. Lights bumbers ,tragets works well.
    Exept, when using the flippers direct the fuse F4 blownout. Checked wiring onderplayfield and they ate acc schematic. Also the three flipper coils were replaced.
    Any suggestion where to look at??
    #2 1 year ago
    I would check the wiring to the flipper coils and the EOS switches. It sounds like something was reversed when the new coils were installed.
    #3 1 year ago
    Quoted from Xenon75:
    Already checked the wiring under playfield but seems to be ok.
    #4 1 year ago
    Quoted from Lambecka:
    Clearly not since the fuse blows. Stern schematics are often wrong.
    If all the regular solenoids fire properly you've got the flippers wired incorrectly - the same wires provide the power to all the solenoids (the under PF fuse is just for the non-flipper solenoids, and that's where the power feed splits off for the flippers)
    #5 1 year ago
    Quoted from slochar:
    Ok wil double check
    But can it be on the driver solenoid board in back box??
    #6 1 year ago
    Ok wil double check
    Double checked wiring of flippersolenoids and they are ok.
    As soon hit the flipperbutton the fuse blows
    #7 1 year ago
    post pictures of each flipper wiring, cabinet flipper switch wiring, and SDB wiring (left side of the board)
    #8 1 year ago
    Quoted from djblouw:
    149DDC2A-DD3C-471A-8452-5498B560A41B (resized).jpeg9CCE9ED5-C76B-4370-9C75-AB679F2B9CCA (resized).jpeg
    #9 1 year ago
    05107DCA-0B39-43B7-9D1D-5C5051EFBFBA (resized).jpeg7F35D971-4DC3-4BA7-83F9-6D7E04EF52DD (resized).jpegA9D0B4E4-D571-40E2-9CCF-7FF1064CBF7E (resized).jpegC96A00AE-EBE7-45F8-9666-D45411F4E084 (resized).jpeg
    #10 1 year ago
    00F05493-B6C4-451D-8A6B-61359E0F36AF (resized).jpeg0F60AC15-2D0F-4157-8A5F-E1D1B7E39B64 (resized).jpeg6D7239AA-609A-4EB3-8BFE-6EA8A72D91CB (resized).jpegB61A65CD-3977-4C3B-9ADA-08E99CF5FC4C (resized).jpeg
    #11 1 year ago
    Is your EOS actually opening when the flipper is fired?....the contacts look really bad (this should be replaced) - possible that they might even be fused together.
    Does the fuse blow when either flipper is energized, or just left or right?
    #12 1 year ago
    By manual operating the flippers the switches open.
    The fuse blow on both side left and right flipper
    #13 1 year ago
    Can you post a picture of bottom right flipper too?
    #14 1 year ago
    0C13DD7E-3CEC-4548-80B2-CFFDCA5F284B (resized).jpeg7F5DEEB9-07B2-4DE7-A001-4A5D06472F04 (resized).jpeg
    #15 1 year ago
    I don't see how your bottom right flipper will open the nearer end of stroke switch.... switch is the same length on both blades and shouldn't be.
    #16 1 year ago
    Ok , did not found that, but you,re right one of the blades is broken, but don,t think this can be the reason for blowup the F4 fuse.
    Will change out the short one
    #17 1 year ago
    [quoted image][quoted image]
    Your end of stroke switch has no way of opening on this coil. So the power is never forced to go through the hold winding. Thats a problem for sure.
    #18 1 year ago
    Quoted from Blake:
    Quoted from Blake:
    You,re right but will that blow the fuse?? Fuse blow a soon as press the button, it blows on the right button but also on the right button
    And ofcourse will replace the broken switcH
    #19 1 year ago
    Under normal circumstances I would say no unless it was being held for too long. And the fact that the fuse blows without using that flipper means thats probably not the issue either. I'm assuming you meant to say "left" button.
    Are all the power wires going to the outer lug with the banded side of the diode? And are all of these wires the blue/white?
    #20 1 year ago
    Also I can't find a schematic for this machine so can you confirm that the top switch on the bottom right flipper is for engaging power to the upper flipper? Are you sure thats wired correctly? I see the switch is in the N/O state, is that proper? Would make sense if engaging power to the upper flipper. I see one wire on the switch is going to the return/GND lug of the coil, where does the other wire go to?
    #21 1 year ago
    Oh and of coarse test all your flipper diodes.
    #22 1 year ago
    Quoted from Blake:
    Here part of scheme showing the three flippers
    #23 1 year ago
    Quoted from Blake:
    Alle diodes installed with band to outer lug with blue white wire on all three flippers
    #24 1 year ago
    From what I can see, I agree that everything looks to be wired correctly. I've compared against my Meteor, and it matches.
    I'd start trying to isolate the flippers now (disconnect all but one, and see if it changes the behavior).
    #25 1 year ago
    Seems like my meteor had a resistor on the upper flipper.
    #26 1 year ago
    I remember fighting my meteor flippers- it wound up that the new coil was bad…
    #27 1 year ago
    Ok wil do that tomorrow, but today already disconnected the right one and same occurred, fuse blows.
    More and more think it must be in the driver board, see picture. Is there a way to bypass this board for testing.. ??
    #28 1 year ago
    The driver board only enables the flipper circuit through a relay. And the relay either works or it doesn't, never seen one cause the fuse to blow. If the transistor that controls the relay was shorted on, you would have flippers all the time.
    Take your multimeter and measure each coil, like a poster said above just because the coil is new doesn't mean it isn't bad/shorted internally.
    #29 1 year ago
    Yes you can bypass the solenoid driver board to test the flippers and see if the solenoid driver board is related.
    Remove the J1 and J2 connectors and jumper the flipper wires as per the picture you uploaded.
    J1 pin 9 orange to J2 pin 1 red
    J1 pin 8 green to J2 pin 2 blue
    #30 1 year ago
    Try lifting all wires from the coils, isolate them by taping the bare ends, then power up and see what happens. If fuse blows, you have a wire/ SDB issue, not a coil issue.
    #31 1 year ago
    Quoted from Rikoshay:
    Did this test and fuse still blow. This proof that solenoid board is ok
    Following step: remove the three coils and inspect coils and diodes
    #32 1 year ago
    Removed the three flipperunits complete and disassembled the coils. Checked all of them with multimeter and coils did not show any value Ohm. Removed all the diodes and measured the coils again and they show the value ohm as per specification.
    Most of the installed diodes are blown up.
    #33 1 year ago
    Need to order new diodes. In the meantime installed the flipperassy withoutthe diodes.
    Startup the machine and flippers work. Fuse stay in
    #34 1 year ago
    Diodes being blown would cause the fuse to blow instantly as it's a dead short when you flip then.
    Don't play the game with the diodes out it will damage things.
    #35 1 year ago
    Its good you found the bad diodes. Replace them as you mentioned. But don't use the flippers without the diodes as the back EMF can damage your drive/predrive transistors.
    #36 1 year ago
    Beat me to it by 46 seconds.
    #37 1 year ago
    Thanks guys for you help
    Will wait for the diodes
    #38 1 year ago
    Quoted from Blake:
    The only thing on the circuit is the big flipper relay, could this actually damage it?
    #39 1 year ago
    Quoted from Black_Knight:
    Good point. I'm guessing the collapsing of the magnetic field is considered a potential hazard to any part and thus they always install diodes. I read sometime ago that the force created by the field collapsing is significant. Also think about the connections going to the relay. Whats stopping the back EMF from damaging further up the stream of the relay. Is that force halted in someway by the relays coil or not. I'd rather not find out the hard way.
    #40 1 year ago
    Quoted from Blake:
    Reading the forum about the use of diodes, seems to be discussion everytime. Iam not experienced enough, so will stay at the safe side. Original these unit were delivered with the diodes installed and must be a good reason in that time.
    I will install these diodes and thank you all for the input.
    Albert
    #41 1 year ago
    Quoted from Blake:
    There is nothing on the circuit until the ground and the BR on the power board, flippers are isolated. The BR is diodes, so, not sure your going to hurt anything.
    There are plenty of coils out there without diodes. I jut don't think this is a circuit that needs them. Would like to hear from someone who actually knows what they are talking about - cause I'm just guessing.
    #42 1 year ago
    Yes I now see the flippers are mechanically controlled and not operated by the CPU. So that rules out damaging drive transistors upstream. That may also mean a diode is not necessary for safe operation. And yes there are coils without diodes. But if we are talking specifically flipper coils, every game I've come across operating flippers on DC current (excluding some new stern it seems) are utilizing a diode inside their particular circuit. This includes mechanically operated flippers on early SS. Lots of newer games installed the diodes on the driver boards or remote boards to keep people from mounting them the wrong way and remove the possible issues associated with vibration from the flippers but they are in the circuit and illustrated in schematics. I stand by the thought its a good idea and the safest way to operate the game.
    #43 1 year ago
    Black_Knight
    By the way cool arcade. How long have you operated vertigo and how’s it been going through all the Covid changes.
    #44 1 year ago
    Thanks for the bump. We just opened in May, so no Covid issues for us, GA has been open since early this year.
    #45 1 year ago
    That’s great! I wish you the best. Place looks like fun.
    https://vertigopinball.com/
    https://m.facebook.com/vertigopinball/
    #46 1 year ago
    Quoted from Blake:
    Still struggling in getting these flippers working. .Try to install the new coils with the diodes installed. Showing two pictures , first is the original schematic showing that the EOS is connected to the power side ( blu white ) and the middle contact of the coil.
    Second picture showing the EOS is mounted between ground site and middle contact, som ot to the powersite. Always worked on EM machines , but this is different
    Also like to know if there is on these coils a powersite (direction). When i installed the diodes, just mounted the band site to one direction.
    Need some help again
    94C27AE4-CA55-4AF6-A53A-830DECF196E2 (resized).jpegA38451D5-FE63-4D3E-AF72-15CB35A22C53 (resized).jpeg
    #47 1 year ago
    Here’s a pic of the diode orientation. 20C3650B-812F-4A2F-A68E-DCC4D40E1B36 (resized).jpeg
    #48 1 year ago
    Yes, there is you should see 2 wires a fat and a thin going to one of the terminals. That is the power feed side. The EOS switch one end goes to this side as well, and the other goes to the fat wire other end (usually the center). The other terminal should have the other end of the thin wire.
    You probably mounted the diodes backwards. The fuse would and should blow instantly on activation as you've noted is the symptom here.
    Post a picture showing the wiring and the diodes.
    #49 1 year ago
    On the animated drawing, showing the lightblue wires , one goes to nonpresurre site and the other to the centre ??
    Problem with fuse was already solved, but one flipper was ok and the rightone only moved a little.
    First i mounted the diodes on the coil, just put them on, was in the understandig there was no difference in how.
    After that mounted the wires and took care that the power wires was attached to the band site of diode, so fuses did not blow. But if now seems is that on the coil itself is as pressure site as well, maybe explain reason why it was on half power.
    Cannt post pictures because already dis assembled all three units.
    Having the coil disassembled, without any wire soldered , is it possible to measure with multimeter what the pressure site is??
    #50 1 year ago
    Here picture of the coil . Only fat wire goes to the right, not two wires
    This page was printed from https://pinside.com/pinball/forum/topic/stern-meteor-f4-fuse-flippers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
