(Topic ID: 272159)
Stern Lightning not turning on/ no display
By xddanx
6 months ago
  • 15 posts
  • 6 Pinsiders participating
  • Latest reply 6 months ago by xddanx
#1 6 months ago
Bought a Stern Lightning not working and looking for 1st steps.
When I turn it on the GI comes on, some feedback noise starts loud then get soft but steady and no display. Start button does nothing.
Where should I start?
#2 6 months ago
Quoted from xddanx:
Taking note of how many LED flashes you get on the MPU and going from there
http://techniek.flipperwinkel.nl/ballyss/rep/index2.htm#flash
#3 6 months ago
1 solid light. Board looks immaculate around the battery and reset area. Still proceed with pulling the board without checking fuses or anything else? First time doing any board related stuff.
#4 6 months ago
Quoted from xddanx:
"If you turn your Bally game on, and the LED stays on continually, this is one of the hardest problem to fix on these boards. "
Yeah all you can do is follow the guide and narrow it down.
#5 6 months ago
I am up to 3 flashes after just pressing in the chips going to explore the 6821 next.
#6 6 months ago
Slowly moving up!
#7 6 months ago
6 flashes now, off to buy some fuses tomorrow.
#8 6 months ago
With the new fuses I get 7 flashes after a long delay after 6. It comes quicker if I give the cabinet or coin door a smack. Still no display or coils firing.
#9 6 months ago
There is a fuse on the playfield for the coils. It is located next to one of the flipper assemblies. It is a one amp slo-blo fuse.
On that vintage of machine, Stern put a fuse for the score displays on the back of the insert light panel. It's also possible "someone" over the years may have replaced the Stern Solenoid Driver Board with a Bally one which "might" have a high voltage fuse on it for the displays.
#10 6 months ago
Any progress on this machine? I have a similar issue with a Meteor that I just fully refurbished.
When I turn on the power, the only thing I get is GI lights remaining on. There is no sound, no score display, no game reset.
I took out the solenoid driver board (which is a brand-new replacement) along with the power supply and did a bench test using power plugged directly into the solenoid driver board. Measuring all the test point voltages turned up positive, nothing showing an odd voltage.
I assume I should test the voltage coming in directly to the machine at the small metal box where the power cord (new) was soldered in? I forget what that gizmo is called.
Any other places I should check?
The only board NOT replaced in the head is the one for playfield lighting.
It sucks to work 8 months on rehabbing a machine and getting nothing when the power switch is tripped!!
-Nate
#11 6 months ago
Quoted from Pinball_Nate:
Have you confirmed you have 5v at the mpu? You can check for 5v at the test points on it.
#12 6 months ago
I’d start with the guides on pin wiki, confirm voltages off power supply and test points. start working through steps from there.
#13 6 months ago
I am still on 7 flashes/ beeps. I went thru and changed some fuses. Still no display or energizing but if I hit one one the test buttons it does a switch test where all the coils fire. What should i focus next on to get the game running?
#14 6 months ago
Thanks frunch and jgreene, frunch I assume there are test points on the MPU, I'll check for that 5v.
jgreene, I have been using flipperwinkle, that's how I found out about how to power up the power supply out of the machine, all test points were fine when I did that.
They also mentioned the square connector running from the body to the head, I will check those connections.
Thanks guys, I'll report back - appreciate the comments.
-N
#15 6 months ago
I changed some fuses and added credits today it it fired up! No display what should i explore to get the display to work?
$ 5.00
Doc's Pinball Shop
$ 6.00
Siegecraft Electronics
nvram.weebly.com
$ 149.95
Allteksystems
$ 119.95
Allteksystems
Displays
PinballSolutions.eu
$ 12.00
Third Coast Pinball
$ 24.00
