I've been working on this Stern Lightning MPU for a while now. I have 3 boards for it, one crappier than the other. I did however have it working fine at one point, I was just working on some switch issues when the MPU died on me, and the LED just stays on solid. I had already replaced the game ROM's U1-U6, which seemed to help it get going initially. The sound cables were another issue but I made new cables which did the trick there.
So after it died I went to the flipperwinkel site and went through all the procedures, I even made a test fixture so I could work with it easier on the bench. I replaced sockets for U9, U11, tested the reset circuit and it seemed to be fine, bought new 6800, 6820's for U9-U10,U11, voltages seem ok, and all sockets seem to have continuity down the line. I spent all day going through every website and procedure I could find, but nothing really makes sense, I still have a solid on LED when I start it up. There is no battery damage, so the only thing I can think is that my U9 6800 or U11 6820 was bad and the new ones I got are bad as well? I bought 2 of each just in case, and neither has solved my issue.
I did the short R1 and R3 to ground test and the MPU dropped to .4v or whatever it was supposed to do, shorted pins 39 and 40 on the MPU and it didn't reset, etc, I think I covered everything I can with a DMM and no logic probe but still no joy. I hope I've explained myself well enough, and I hope someone can shed some light on this problem, I know it can be hard to find. Thanks.
