Here's how mine is set up, both post screws are top threaded so post caps can go on both ends. One nut on each side holds the posts, the other two nuts hold the spinner frame, so the spinner is higher by the thickness of the extra nut. It may not be original but I honestly don't remember setting it up like this on purpose so it was probably like this when I got it eons ago. Just too long ago to remember. Anyway my spinner has always spun very fast on hits and and I can easily make the ramp.
If you take the spinner off, can you then make the ramp a ton easier?
