Hello
Never dealt with issue with a spike game before so complete noob here
1. Turned KISS on today (it was updated to new code last weak with no issues)
2. Pressed start
3. walked away from the game for 5 minutes to get a snack. after 5 minutes i heard a noise like the ball hand ended and ball 2 started
4. walked in the room to see a score of about 800,000. ball in shooter lane, no one was around!
5. Noticed that the top right quarter of the pin was dark.
6. Turned pin off, waited 30 seconds, and turned it on again
7. all 3 ball ejects (GENE, star eject, and scoop) where going off on its own, about 5+ times each.
8. after that, it gave an operator error.
9, opened door, 3 tech alerts . Device malfunction for STAR EJECT, SCOOP EJECT, DEMON EJECT
I've heard about node board issues, so i put the PF up and looked at the black boards.
All of them have a Orange LED flashing quickly on there except for 1 of the smaller ones. pictured here.
The larger one under seems to have a weird looking fuse on it, but i checked the continuity on both boards and they are fine.
I went into the menu and did a node board test and everything seems fine??
photo_2016-04-27_21-29-57_(resized).jpgphoto_2016-04-27_21-29-39_(resized).jpgphoto_2016-04-27_21-29-44_(resized).jpg
photo_2016-04-27_21-29-51_(resized).jpgphoto_2016-04-27_21-29-44_(resized).jpgphoto_2016-04-27_21-29-47_(resized).jpg
I did a lamp test, as before all the top right corner of pin is off.
i did a flasher test, no flashers flashed at all.
I turned pin off, took all 3 cables off that little board, plugged them back in and turned pin on, didn't fix.
Thanks for any help
