New! Dark mode!
(Topic ID: 254211)
Stern Jurassic Park 2 Custom Audio Project
By hawkmoon77
12 months ago
  • 1,037 posts - Hot topic!
  • 182 Pinsiders participating
  • Latest reply 2 hours ago by mayo
  • Topic is favorited by 185 Pinsiders
There have been 23 images uploaded to this topic. (View topic image gallery).
13 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 1037 posts in this topic. You are on page 16 of 21.
#751 32 days ago
Just caught up on the thread...just thinking out loud here, but what about game accessories or specific game settings; for instance shaker motors and it’s associated game option?
Tim, you have an LE with shaker right? I have a premium with shaker and I don’t have any problems. Does someone that has seen the reboot have a shaker installed? Just throwing that out there...
#752 32 days ago
Quoted from skogen75:
Yes, I had the Trex reset issue and I have a shaker motor installed on my premium. I did notice however that during that sequence somehow the video reduced into a window within a window on the display rather than filling the whole screen. Perhaps this combination of a graphic transition and the video are at fault
#753 31 days ago
I have an LE with shaker and as stated above it did reboot once.
#754 31 days ago
I have a Premium with shaker motor and it rebooted for me 3 times in around 20 games with this card:
amazon.com link »
I have since switched to the following SanDisk card and so far after about 20 games it hasn't rebooted at all:
amazon.com link »
I'll admit that it doesn't make sense that the brand of card would make a difference. both cards are class 10 16GB cards and I used Win32diskImager to write both of them. I fully expect the SanDisk card to cause a freeze/reboot at some point but so far it has been solid.
#755 31 days ago
Anything's possible in this mystery! Yes I have an LE with shaker set to default settings. I never get a reboot with this latest code.
#756 31 days ago
Quoted from MikeS:
amazon.com link »
amazon.com link »
The SD that isn't rebooting for you or me is the exact same one I use. Only caveat is I have some 32 GB ones of the same type and some 16 GB but never a reboot with my LE. amazon.com link »
#757 31 days ago
Not to ignore hardware possibility entirely, the main thing that changes inside an brand of SDcard is the controller. The specific controller used defined the speed at which data can be accessed in a sustained fashion. There is a possibility that a card with slower read could cause some of the rest of Stern's real-time operating system code to timeout. This is a very long shot, because for slower reads, I would expect to see stuttering, not crashing. And I know that Stern uses the lower cost "MLC" type memory cards, which are slower in most cases.
But, anything is possible, so we need to keep looking for cases that CAUSE crashes. (Ironic, but keeping track of cases that DON'T CRASH is less helpful, because any sequence related issues simply may not have occured on those machines: e.g. Hitting Skill-shot, followed by a Trex multi-ball, and then a Jeep rotate.)
Still just looking to eliminate variables...
#758 31 days ago
I think it also makes sense for someone with the freezing issue to send their SD card to someone who does not have the issue and have them try it out on their machine.
#759 31 days ago
So yesterday I had a crash, typically my sd card works, I used win32 disk imager and the stern stock card and the audio hangs up a little on trex chase with the roar coming late, no big deal. However yesterday I started king of the island and trex chase at the same time, and that crashed the game. Just a heads up figure more info can't hurt.
#760 31 days ago
Quoted from dreamtheme:
We’re still looking into this but seriously, the stern card is garbage. To have a chance for it to work well, spend $7 and get the sandisk card that I recommended earlier which has been great. That’s not the definitive answer but what could be a PB issue, give yourself the best shot and get a good SD card for now
#761 31 days ago
This is starting to feel again like a software only problem. If I am keeping score properly, the Stern software on the stern cards doesn’t crash. I don’t see a single report of a crash using unmodified 1.02 or 1.02 with audio only mods. It’s only when more complicated video clips are added that it seems to crash “some of the time” on a myriad of card types.
Feels like software to me. Either the video encoding or a bug in PB itself.
#762 31 days ago
Quoted from Markharris2000:
Yes you are correct in that nothing like this has happened for anyone with my audio only edits versions (after many versions at this point).
JP is not the only code suffering from this issue when it comes to video imports. Aerosmith is too as per this post: https://beta.pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images/page/84#post-5859093
To your point, I'm also leaning toward a software / PB issue, not SD card type related.
I sent my simple test details over to the PB dev today (the ones I posted here: https://beta.pinside.com/pinball/forum/topic/stern-jurassic-park-2-custom-code-project/page/15#post-5855669). Will let you know what he says.
#763 31 days ago
Wait a min, did you just say that stock 1.02 code is giving you this issue?
#764 30 days ago
No, the new 31TS code. The sd card i used was the one that came with the game but with your new assets. I dont get king of the island very often and thats the only time its crashed.
#765 30 days ago
Question for those of you in the TMNT alternate code thread as well, are there similar bugs/crashes with the alternate audio/video code that was created for that machine? Same hardware, correct?
#766 30 days ago
vicjw66 Why did you downvote this post? markharris2000 has been helping troubleshoot all of the issues in an incredibly helpful and precise manner. If you're going to downvote someone, you must have something to say as to why. Was this by accident? I have not seen you post anything on this thread. Please spend your time on this thread helping not hurting the cause. Thanks.
#767 30 days ago
Please follow the directions timlah and delt have laid out. Save your SD that came with the game and fork a couple bucks for a Sandisk.
I’m over a week and nearly 50 games w/no issues 1.02 code. The benefit to following steps is easier to trace issues. Lets try to help and be as consistent as possible.
#768 29 days ago
I've played countless games with the new code on my LE and only had it reboot once when I initially installed the new code.
Is this a problem that is recurring for others?
#769 29 days ago
Quoted from Ramzr1:
Yes, there is something causing crashes in the 31TS audio+video build, whereas the Stern factory stock 1.02 and the audio-only 29TS do not. While we don’t know the cause just yet, appears that it could be a sequence of play that causes crashes when accessing a video clip. Still lots of unknowns and we’d love to hear about the specific brand/size SD card you were using when it crashed just to try and help track it down.
#770 29 days ago
Quoted from Ramzr1:
Mine has been the same. Im on 29TS I believe (could be mistaken) it was the code with the initial video mod. Had it reboot once within 2 or 3 games, and haven't had it happen since *knockonwood*
I cant remember if this was mentioned or not, but is there a version where "3, 2, 1" was kept and NOT replaced with "you didnt....say...the magic word."? Having a count down say 5....4....you didn't...say....the magic word." Is kind of awkward lol
#771 29 days ago
In my last note #769 I made a statement that regardless of brand of SDcard, when running factory 1.02 or when running Tim’s 29TS audio mod code, we have NOT seen crashes on anyone’s machine. I WANTED TO CHECK THIS STATEMENT FOR ACCURACY to be thorough in the process to track this down. If you have an experience that conflicts, please let us know as much detail as possible. Card type, how you wrote the binary image to the card, which version of the software, how long you had been playing the machine since it was powered on, how many games since power on, how deep into the current game were you when in crashed, and what shot you were making when it crashed.
#772 29 days ago
Quoted from FatPanda:
Mine has been the same. Im on 29TS I believe (could be mistaken) it was the code with the initial video mod. Had it reboot once withing 2 or 3 games, and haven't had it happen since *knockonwood*
I think you were running 30TS the first video+audio mod
#773 29 days ago
29TS is the latest audio edits only version. 30TS and 31TS are the only video edited versions.
Yes I know that's kind of awkward when fake Arnold does a countdown outside of smart missile. The same sound locations are used by the game for both a mode countdown and smart missile. It's on my list to revisit.
#774 29 days ago
Quoted from timlah79:
Slacker!!!!!!!!!!!!!!!....haha.
#775 29 days ago
Which version is better 30TS or 31TS, i have no issues with 30TS and have 31TS on another SD card ready to go.
#776 29 days ago
Quoted from mzhulk:
They're barely any different. IIRC 31TS was the one delt added the stock T-Rex roar animation to try to quell some of the restart issues so that's the one I've been sharing. Not sure if it has helped. If 30TS is working for you I'd stick with that for now.
#777 29 days ago
markharris2000 Yes you are correct in that any of my audio only edited versions have never had this or any similar issue. It's only the video edited version(s).
I did some testing just now and am dumbfounded by the results:
Using:
- A known, working SanDisk 32GB Ultra SDHC UHS-I Memory Card - 90MB/s, C10, U1, Full HD, SD Card - SDSDUNR-032G-GN6IN
- Balena Etcher on PC
- A copy of my latest audio only edited, proven to not have issues, NO videos touched whatsoever.
1) Using PB video import (the first option with conversion) > import an intro video to a video location that is known to work with the latest video edits code
NOTE: This is the intro fly in and I first exported the stock video to check the duration. While my customized intro is 00:26, the stock file is 00:23. However with that said it's worked fine for me and many others at that slightly extended duration. In summary at this point I don't think "duration" is an issue.
2) Save and flash that code to SD using PC Balena Etcher
RESULTS:
GOOD!: SD loads without any initial restart loop
BAD!: Upon starting a new game, the video that plays by default before you hit start freezes and game restarts OR game / video screen just freezes.
3) Make a new copy of my latest audio only edited, proven to not have issues version
4) Using PB video import (the first option with conversion) > import the same intro video aka step # 1
5) Save and flash that code to SD using PC Win32DiskImager
RESULTS: ALL GOOD! SD loads without restart loop and game starts and plays my custom intro video without issue.
I am still so clueless at this point as to what is going on here. I can only think that A) Duration of an uploaded video doesn't matter, B) That there must be something different in the way Balena vs. Win32 flashes when there are video changes involved, and C) That there may be something going on with the conversion PB does or with how JP in particular handles custom video when it's custom.
If it helps here's a detailed screenshot side by side of each .mp4 files exported from stock, custom video created, and exported custom video.
From left to right...
1) Stock video exported from PB
2) My custom video I created with iMovie
3) An export of #2 from PB (after I imported # 2 to that same # 1 location)
For # 3 I do see a difference in Total bitrate and Frames per second. The PB import (using conversion) is supposed to correct this and I think it's supposed to match (stock) # 1 but I'm not sure. Perhaps the fact that PB isn't adjusting the Frame rate properly is to blame for all of this??
I suppose the next thing I'll try is to convert # 2 to 30fps prior to uploading. Wanted to at least share these findings for you/those who understand this video stuff better than I do.
As a follow up to this, I took it all back to the PBrowser dev and tried all of the above steps with a stock JP 1.02 download. Same results. I sent him the most meticulous of details and he has no advice other than that Balena Etcher is unreliable if you're trying to flash code that has video edits. You'll need to use either the PBrowser's flash tool or Win32DiskImager.
I even took it a step further today and experimented with importing videos from my working audio only edited version. I got some errors upon hitting save in PB during one import, but as long as I flashed the result using PB's feature or Win32DiskImager, the game loaded up just fine and no restarts have happened in game. Plus all like 6 of my custom videos are playing without issue.
What I did do is make sure each video I import is the exact same timing as the stock. The current 30TS and 31TS versions do still have videos that are longer than the stock ones which I feel is always going to pose a problem. I think it's best practice to only import videos OR sounds with durations in parity but at the same time who knows if that's even part of this issue. In no way am I saying that Delt's longer videos are the root issue here, it's just a hunch b/c I know from all the audio work I've done A) the duration limits the playback of a given sound and B) b/c of A I've been meticulous about adding sounds that are <= the stock's expectation and C) If you import a longer video, the firmware + game triggers don't limit its duration as it does with audio imports.
It's also important to note that other folks importing videos to other game firmwares are having the same issues (a recent pinsider has been struggling with the same with Aerosmith for example). So I'm just saying that this isn't JP specific. This still could be a PB bug OR just a standard Stern bug when it comes to all the variables involved in video files (frame rates, duration, size, aspect ratio) in general.
Moral of this story currently IMHO:
Don't use Balena Etcher if you can avoid it.
PC users need to use PB for flashing to SD or Win32DiskImager. Do not use Balena Etcher.
Mac users - we need to find a reliable flashing app for you. I really don't know what else is out there but a different app could be the end all resolution for you guys.
#778 29 days ago
My advice to the Mac guys: (myself included). Use terminal to write the code, I’ve had no issues doing it this way.
#779 29 days ago
Quoted from dimthedaylights:
I am aware of the terminal way of doing it but I've never tried. I also feel like it's super sketchy if you don't know what you're doing. Would you mind posting precise steps that we can share with Mac users?
#780 28 days ago
Just followed this: https://www.raspberrypi.org/documentation/installation/installing-images/mac.md
Mac running Catalina
#781 28 days ago
This might be the solution for Mac folks but we'll want to provide specific numbered steps to follow. Not too many pinball machine owners are "software" tech savvy. While I understand the steps, there's minutia in between in that article and no 1-2-3-4 etc. What I was looking for was for someone who has used this method to help other Mac owners by writing down exact numbered steps, A-Z for this JP code specifically. If you'd be willing to write those up that would be awesome. I'll include them in the responses I send out and mark your post as a key post to help Mac users.
#782 28 days ago
Quoted from Vino:
Same here, once on initial startup, no crashes since
#783 28 days ago
Quoted from Ramzr1:
Same here, once on initial startup during trex multiball, no crashes since
#784 28 days ago
I had now 1 crash during T-rex multibal and the first paddock was running. Played over 25 games. Will test this more.
#785 26 days ago
Hey timlah79 - Question about the game code... I noticed (I believe) that the intro theme plays in the following three places:
-Start game
-During an active paddock session
-Immediately after a successful capture
Is that accurate? And if so, does the code use the same sound file for all three, or is there an opportunity to perhaps diversify them?
#786 25 days ago
Scroll earlier in the thread. I used the dd method on my Mac successfully when etcher on the Mac or pc didn’t.
#787 24 days ago
Im just now catching up on this project - I had been following an old thread apparently so I missed the announcement.
I am at work so I haven’t read every single comment but could I pay someone to load this to the “best” SD card for me and mail it? I’ve got an old hackintosh and I worry that I won’t be able to get all the steps right just because of that alone lol
I’d love to try the audio + video version but I think I’ve become so acclimated to the animations that audio only would probably be my ultimate preference.
#788 24 days ago
Quoted from mcvetyty:
-Start game
I haven't touched the music in any of these areas.
-Start game
[Tim] Expected.
[Tim] By during if you mean a loop of the intro them is playing that's definitely unexpected. If you mean you heard it at some point I'd say that's expected. The game chimes the intro music in in a few modes.
[Tim] Expected.
- And if so, does the code use the same sound file for all three, or is there an opportunity to perhaps diversify them?
[Tim] Likely yes but it's possible that they are triggered with their own sound scripts. I haven't looked into it.
I haven't changed the music additions since a few versions ago and I don't plan to. There are already 21 music replacements. It's the callouts that I plan to adjust / add in later versions as I feel there's still room for improvement there despite the hundred or more I've already replaced.
If you could take a video of what you're seeing + hearing that would help!
#789 24 days ago
Quoted from r00DVM:
There's a lot of red tape here. Please PM me and I will help you get it installed.
#790 23 days ago
I finally did the update to latest version while doing install of Pinwoofer system yesterday. I played probably about 10 games afterwards, everything working flawlessly. T-Rex video and sound syncs properly etc. Absolutely no faults to be had across many modes I checked out.
13
#791 23 days ago
Started messing with end ball / bonus video options the other day. It's a commonly looked at sequence that I feel needs some love. Just when I told myself I'd stick to audio only.. Gah!
LMK what you guys think. This short end ball video consists of 3 in game videos that I had to meticulously time together with 5 movie clips.
#792 23 days ago
I think it looks fantastic.
#793 23 days ago
Looks excellent Tim!
#794 23 days ago
Nicely done!!
#795 23 days ago
Super fun and well done, as always, Tim!
#796 22 days ago
I love what I have.........no moreeeeeeeeeeeeeee.....LOL.
I guess I will be a expert on flashing sd cards if you keep adding these goodies.
Just when I thought I was out , you pull me back in. Evil Genius.
#797 22 days ago
Is another version coming soon? Just want to know if I should leave my backbox open... LOL
#798 22 days ago
Looks incredible Tim! I can’t wait for the next update
#799 22 days ago
Quoted from N80G80:
Looks awesome Tim!
#800 22 days ago
I think so.
$ 69.50
$ 279.95
Pin Stadium Pinball Mods
$ 18.95
