(Topic ID: 254211)
Stern Jurassic Park 2 Custom Audio Project
By hawkmoon77
  • 1,822 posts
  • 295 Pinsiders participating
  • Latest reply 12 months ago by robin
  • Topic is favorited by 291 Pinsiders
7 key posts have been marked in this topic
Display key post list sorted by: Post date | Keypost summary | User name
Post #955 04: DO NOT SHARE YOUR PRIVATE LINKS WITH OTHERS Posted by timlah79 (2 years ago)
Post #1145 06: Stats on the customization work from audio to video (as of 38TS) Posted by timlah79 (2 years ago)
Post #1773 01: PSA - PLEASE DO NOT ASK FOR A 1.06 VERSION Posted by timlah79 (1 year ago)
Post #1784 00: PLEASE READ: Do not request custom code Posted by timlah79 (1 year ago)
Topic indices are generated from key posts and maintained by Pinside Editors. For more information, or to become an editor yourself read this post!
This topic is closed.
There are 1,822 posts in this topic. You are on page 1 of 37.
#1 3 years ago
Here's a place to stay organized and updated about working on custom audio for Stern's JP2.
Whose working on it:
hawkmoon77
timlah79
What's been done:
Sound clips are being extracted from the movie and cleaned up. I'm at the 10 minute mark and already have 30 clips.
Audio in the code is being indexed and labeled (I've done around 600)
Got a process to get clean dialogue from the movie using spectral analysis. It currently takes about sn hour a clip though
#2 3 years ago
So one of the neat things in going through the code is how many music and FX files I haven't heard before, in nearly 250 games. Perhaps they are there for future modes? Based on some of the background music, they seem like they will be exciting.
#3 3 years ago
Thanks for whipping up this topic hawkmoon77 !
Quoted from hawkmoon77:
Just out of curiosity, which channel in the mix are you extracting the audio from? And are there non-vocal channels that can be used for noise reduction?
You brought up a good point. I am ripping these from a streaming version of a stereo high def version. But now you make me wonder if I could somehow extract surround channels from a remastered DVD, if say the speech is more separated to the center channel or something, but I kind of doubt it b/c the original was not recorded in surround AFAIK. So any surround version would be faking it unless they started from the original recording track outs. With the stereo files, in some cases the speech is panned closer to one side than the music, which makes it easier to separate but it's hit and miss. The sounds will have background music/environmental noise no matter what, but my engineer and I are working with some pretty good plug ins. In the end as long as there's a layer of sound going on in the gameplay, the unwanted b/g is far less noticeable. I'll look into the DVD option but that may be difficult to extract due to security measures.
#4 3 years ago
Hey hawkmoon77 I see you've updated a ton! I just added a few myself using your same naming convention. One concern though. When you try to search/use the text box to filter to one of your custom bookmark values, it doesn't find it. I can only find it from the original Request #. Hopefully I'm just doing something wrong?
#5 3 years ago
Quoted from timlah79:
I suggest starting from the most recent version of the movie... I think it is the remastered bluray. They would have already done a ton of work cleaning the audio for the center channel, but for the older stuff like JP, they might have rerun clean back tracks for the stereo channels with left the center mixed. What I do is preserve the channels during the cutting of the clips. Then, you can usually subtract the left and right tracks from the center and you'll be left with really clean audio.
Sometimes, you only need to subtract one side or the other. Or you may need to mix the left and right, and then subtract from the center. It's worth checking the rear channels too.
Also, you need to use the most uncompressed format, or the subtraction won't work right.
Once that's all done, you can usually just normalize the volume of what's left and be good to go.
#6 3 years ago
Hmm.. search is working for me. It may be a glitch.
By the way, did you see Request 710? One of my favorites.
#7 3 years ago
Gotcha, hmm. I don't own the DVD or Blue ray, just the '93 VHS! And of course soundtrack CD and vinyl (but we're not replacing music). You seem to be somewhat audio savvy on the video audio extract front. Do you own any of these/could dump files out the entire audio channels for me to cut up and mix? If not I'll just buy it. I'm guessing my engineer has a tool. Let me share what I have so far and let me know if you foresee problems. I'm importing some sounds now and doing a new firmware build. Will report back. BTW one thing that is lame with importing these edited firmware files vs. Stern's official is that it wipes everything score-wise, setting-wise etc. Unsure if there's a way around that?
#8 3 years ago
YES and I'm replacing that now. That was a tough one, super quiet with music and FX in the background.
#9 3 years ago
I just checked and apparently it was one of the first movies to be done in DTS. The audio might be clean in the mix.
I think this is worth a shot considering the time it takes to remaster this stuff. Without even messing with removing the security features, you could play the DVD in a software player that let's you select only the center channel. You can use just about any audio recording software and "record" the audio while it's playing by selecting the recording device as your output. It'll make a clean digital recording. I've done this a lot without a problem.
If it doesn't work, it may be worth buying a legit "digital copy" file and then extracting the audio from the MPEG.
#10 3 years ago
My neighbor has the bluray. I'll borrow it from him this weekend. I think I'll simply pop it in and lower the volume of all of the speakers to zero, except for the center, and see what we got to work with.
#11 3 years ago
By the way, you may want to download the closed captioning file so you can search for phrases in the movie that might work.
#12 3 years ago
really excited about this guys. As I mentioned before I started working on it a little but honestly rather play more of $$ contributor than doing it myself considering my other project (ghostbusters custom code) is still not done yet. So if we need to buy some digital versions of it, lmk.
Lmk how I can help.
#13 3 years ago
If you rip the 5.1 audio from blue ray and import it into pro tools, you will have separate channels with all the dialogue in center. Then you will get very clean dialogue. Easy to do.
#14 3 years ago
Yeah I dunno what's going on but this is driving me bonkers. Pretty sure I have the latest version of Pinball Browser. Maybe not? I have 6.61
#15 3 years ago
"Holy crap, rewriting a brand new game? That's bold AF", I thought.
Then I read the first post, and it's just pinball-browsering the audio. Cool. Noble. Will be loved by many.
Not 'custom code' though.
#16 3 years ago
Quoted from epthegeek:
Curious, what would you change in the code?
#17 3 years ago
Quoted from DK:
I wouldn't. I think the code for JP is great. I just think the thread title should be something more like "Custom audio package for JP2".
#18 3 years ago
Im really dumb on all this, but does this audio extraction software exist similar in pro tools?
https://www.audiosourcere.com/products/
"DeMIX Pro combines cutting-edge sound isolation algorithms with an advanced spectral audio editor to provide audio engineers, producers, DJs, and Musicians unrivaled freedom to create isolated vocals, drums and other instruments from existing mixes. Ideal for high-quality vocal separation, instrumental creation, and production quality sampling. DeMIX Pro delivers unmatched flexibility over other audio separators by offering unlimited, non-destructive track separations, convenient merge tracks functions, a built-in multichannel mixer and its ability to provide the separated vocal and its associated reverb on individual tracks for total vocal control. Separate and Isolate vocals, drums and other instruments using our automated and user-definable separation options. Refine your separations using our intelligent spectral editing tools to create countless high-quality individual track separations for remixing, up-mixing, re-mastering, and post-production applications. Manipulate audio mixes like never before.
I couldnt figure how to get demo to run.
Please excuse me if this is wrong.
#19 3 years ago
Wow.....interesting
#20 3 years ago
i started this too ... how do you share bookmarks ? i can see hawkmoons when i hit sync
also , please share which programs can isolate center channel .. i have been using audacity for everything (walking dead work)
thx
EDIT : i found the vocal isolator (way at the bottom of effects) .. cant believe i didnt know it was there.
#21 3 years ago
Fair and good points guys. Yes right now we are just looking at audio, specially script customization. hawkmoon77 go ahead and clarify the title. Let's stick to the effort at hand though moving forward!
#22 3 years ago
Oh... Sorry to have not been clear with that.
#23 3 years ago
Fixed.
#24 3 years ago
Quoted from ezeltmann:
thx
EDIT : i found the vocal isolator (way at the bottom of effects) .. cant believe i didnt know it was there.[quoted image]
Vocal isolator with center channel gets you like 95 percent there. Some clips do better with audio subtraction though.
#25 3 years ago
I'm working on getting a clean dts audio file to work with. I think it would help to keyword search the script for the 2nd and 3rd movies. Some of the actors were in them and had some useful lines.
#26 3 years ago
Super excited about this project. How does the custom audio work if Stern releases a software update. Is it easy to transfer the work that's already been done to the new version?
Thanks again for all of your hard work. Happy to contribute to a go fund me or something to buy some dinner or adult beverages for you guys!!!
Brian
#27 3 years ago
This is just great.
Hoping for animation customization coming up in the future.
#28 3 years ago
Sounds like this may be the way to go after all. Assuming you're cool with sourcing the full audio tracks and sending them my way, I'll happily take point on edits and clean up from there. Lmk. I'll be out of town until next Thur but will check back in and get back to this as soon as I return!
#29 3 years ago
I'm still learning pinball browser but it seems that everyone's bookmark edits are saved and sourced to/from the same place (just use that sync button to "share"). Which I hope is the case b/c that makes sense. The only downside would be if someone synced an incorrect bookmark it will overwrite the correct one someone else already created. I assume it has logic that disallows someone's blank entries to wipe out existing. Again not sure. Doesn't look like the creator has supported nor updated it since 2016. He still got my $20 though LOL.
#30 3 years ago
Quoted from pinghetto:
Brian
Great question. I bet someone on here knows. I'm going to assume that once the next stern firmware is updated on the machine it will overwrite any custom sounds imported the customized before version. However when you update you do get an option for quick or full. Maybe quick only applies the difference between the two firmware versions?
#31 3 years ago
Yes, each new code update from Stern will revert the audio back to stock. Quick or Full won't make a difference. Then another audio mod will need to be made. So users have to decide to leave the older modded code in place or update from Stern and live with the stock audio until a new audio mix is released.
I'll use TWD as an example. Most TWD owners run custom audio from Cleland, it's fantastic. Whenever Stern releases a code update then Cleland has to make a new version of his modded code and re-release it. Some changes are more difficult than others. If Stern changes the bookmarks then that creates more work.
Junky
#32 3 years ago
Could you take pinsound for data east and get a folder full of wav files from jp already cut up and ready to go?
#33 3 years ago
Quoted from Wickerman2:
I was thinking about the same thing earlier so I checked their website and it was available! This should help out. I'm linking to my google drive see below.
This is for voices only from JP Data East along with the JP remastered version:
Remastered VOICES ONLY:
https://drive.google.com/open?id=1Q4oHDfqx_M1Pu1aTgWHRSi5BW_ns5Z6B
JP DE Original VOICES ONLY:
https://drive.google.com/open?id=1Ymhd6CsmIFLx1GPRGRaVSo_tKvmWgr7-
Looking at the entire JP DE folder, that main theme song is so good. I might even put that into Stern...haha
EDIT - FULL files for each (includes music etc) -
Remastered Original:
https://drive.google.com/open?id=17QA4Qeg2ZsAcHwllyCLatj8M0-3P4G84
JP DE Original:
https://drive.google.com/open?id=1ZF___m0TYdXmFTTiCKNiB4XLCLA56vsu
#34 3 years ago
Quoted from delt31:
JP DE Original:
Wow great find guys! I just downloaded these directly from pinsounds and listened to a few of the same ones I edited I think the remastered ones here are equally as good. If these work out this is going to save a ton of time. Super props to whoever pulled this together.
#35 3 years ago
As I go through the existing audio, there are some pretty good alterative arrangements of the theme songs already in the code. I'm not sure when/if they get used.
#36 3 years ago
Holy cow did that take a looong time. I processed both the 5.1 original DVD and the 7.1 surround bluray. Both versions have a mixed center channel (dialogue mixed with music), but only music on the stereo and rear channels.
Not great at all. But I couldn't even just subtract the stereo from the center. They did some pretty strange processing on it that was messing me up. I finally worked out a way to undue most of it, and use it as a reference to isolate the vocal.
I now have about as clean as a version of "Welcome to Jurassic Park" as I think is possible. I can't explain the subtlety of how much better this method is than my earlier attempts. Virtually zero music intrusion, and a preservation of the vocal that captures the gritty-ness and breathy-ness of the original. You barely notice how much better it is unless you compare it side-by-side to the processed, mechanized, and clipped junk that were my first attempts.
What's the best way to get this file out there? I'm actually pretty eager to hear your thoughts on how it came out.
#37 3 years ago
Here's the link to the dialogue I isolated. (It's in a crappy youtube format, the version I have is a bit cleaner).
#38 3 years ago
awesome! Google drive or
https://www.filedropper.com/
up to 5gb
#39 3 years ago
Quoted from delt31:
up to 5gb
I uploaded it to youtube for now in the above post. I'll look into using a google drive. I'm not sure how google treats ripped audio files though, so I may just set up an ftp server.
#40 3 years ago
sounds about as good as it can be .. great work
#41 3 years ago
Thanks. Now that I have a good procedure, I'm trying to set up a macro so future ones won't take an entire weekend!
#42 3 years ago
Following this thread -- have a premium on the way, but those callouts...
#43 3 years ago
Quoted from KevInBuffalo:
Feel free to participate. If you find good candidates for replacement, let us know.
#44 3 years ago
It took me awhile to figure out what in the world request 630 was supposed to be. I finally realized it was Nedry saying, "one."
There is so much background music that you can barely hear it. They must have just grabbed it from the movie. Wow is it bad...
#45 3 years ago
I have about 40% of the sound requests labeled.
#46 3 years ago
you're killing it!
Where are you planning to host the audio clips?
#47 3 years ago
Quoted from delt31:
you're killing it!
I'm going to turn on my ftp server. I just need to configure the dyndns address.
#48 3 years ago
By the way, I'm going through the FX clips because some of them are generic sounds played during certain win and loss events. It might be good to layer appropriate movie dialogue over it.
#49 3 years ago
FWIW, that really doesn't sound right to me.
Looking forward to hearing the fruits of your labour though. Don't have a machine, but the movie mix for DE JP is awesome.
#50 3 years ago
Quoted from rubberducks:
Could you elaborate on that? It was taken from the scene where they see their first dinosaur. Dr. Grant just finished asking about the T-rex, and then gets light headed. Dr. Sattler tells him to catch his breath. Then Hammond says that iconic phrase as they roll up to the dinosaur. It's about 21 minutes in.
If it helps, I can put the two clips side by side.
arcade-cabinets.com
Armor and blades
$ 19.00
NO GOUGE PINBALL™
Other
This page was printed from https://pinside.com/pinball/forum/topic/stern-jurassic-park-2-custom-code-project and we tried optimising it for printing. Some page elements may have been deliberately hidden.
