Quoted from DonnyBrsco:I've had no luck on my pros trying to link them with the same switcher and sd card to try SiC while i waited on a pro kit...I thought it was a pro vs premium qr reader thing as I have a gdz premium..But that notion went out the window after trying it on ehoh. I've done a full update, new sd card image and I can now connect my imdn to SiC but I don't have node boArd 9 seen so no upper lights.. Not sure what I'm missing but I see you guys having this working is making me jealous ..I may just call it quites and take it as I sign to wait..arghh
Are you using the same switch? And making sure you are using straight through utp cable?
Did you add the micro sd card to your other games?
Just make it work through your switcher to your Godzilla first. That will help isolate your issue and confirm your switch is good. Then add another output and move Godzilla to that and repeat. Then you have a known good switch and output. Then swap the cable to elvira. If it doesn’t work, check where you plugged it in, that they have the required software and micro sd
