The left flipper on my Stern Hot Hand has stopped working. This machine is my only Stern and the oldest I own, can a little unfamiliar with it ( only had it a month). I have so far re-pinned all the connectors to the Power Rectifier board as those pins looked pretty worn. I have no replacement pins for the J1, J2 etc up in the head box, but have removed and reseated each connector. Cant replace the pins on that currently ( do have a few spare, but no way near enough to replace all the connectors)
I then dismantled and cleaned all the flipper parts & replaced the coil sleeves which were extremely black, & re-soldered the wires to the coil. Still no luck.
I have now removed both coils and swapped them over the opposite side. The left sided flipper still does not work, although I can see it trying to move and can hear it powering up. After several flips I can now get the left to occasionally fire off - although its weak and only will do so once. The right sided flipper is working perfectly after the coil swap, so assume that both coils are fine.
The left flipper button appears to be making perfect contact - the wires to the flipper button also look well attached & cant see any issue there.
Fuses have all been removed, tested and checked. No issues there.
It looks like there is not enough power firing into the left coil to power a shot. Flipper movement appears free and fine.
Anyone offer any suggestion to what I should be looking for next to fix this flipper - thanks in advance for any help offered
