Hi All,
My Godzilla recently developed an issue with the building hit opto no longer working. I've had the pin for 3 months and for most of that it worked fine but now it doesn't register in test mode.
When I checked under the playfield the wiring to this opto was quite tight so it may just need the soldering to be fixed. Can anyone point me to instructions on the best way to remove the optos?
From what I can see I would need to remove the two powerline switches at the front of the building (47 & 48) which would allow me to lower the bracket for the optos but I would also need to unscrew the plastic attached to the top which has the bridge in the way. I just want to make sure I don't start taking things apart that don't need to come apart.
