(Topic ID: 300354)
Stern Godzilla Official Owners Club King Elwin
By beltking
2 years ago
  • 27,662 posts
  • 1,658 Pinsiders participating
  • Latest reply 2 hours ago by hypnotoad
  • Topic is favorited by 1,036 Pinsiders
Topic poll
“What model did you order?”
  • PRO 289 votes
    20%
  • PREMIUM 908 votes
    63%
  • LIMITED EDITION!!! 243 votes
    17%
(1440 votes)
25 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27,662 posts in this topic. You are on page 547 of 554.
#27301 43 days ago
Quoted from Mully911:
Went to PinBrew and picked up two sheets of Voodoo glass for my Godzilla and Monster Bash remake. Anyone ever sell the original glass?
i have purchased the original glass from someone who did that exact same thing. super nice to get non scratched glass on and older beat up machine.
#27302 43 days ago
Quoted from badfish981:
Easy process to replace the T molding?
Super simple. When you take the old one off you can see how they cut it for corners..just start the new one at the bottom, and when you get to a corner, make a cut. I'm sure there are videos.
#27303 43 days ago
Yup. 20-feet of wooden channel, and press-fit plastic T-molding made for that space. Really quite easy....
#27304 43 days ago
After having issues with a friends premium for a few months , I've tracked down problem, originally game was dead, I found power distribution board had a fried chip. Ordered new board, installed , blew up instantly. After months I found the issue. The Magna Grab magnet fried. Game will finally boot with it unplugged. I've ordered another board and magnet coil, should there have been something to prevent the board from blowing? And should I look for anything that would have caused the magnet to do this before installing the 2nd new board and new magnet?
PXL_20231130_201100877 (resized).jpgPXL_20231130_201100877 (resized).jpgPXL_20240412_180754164 (resized).jpgPXL_20240412_180754164 (resized).jpgPXL_20240415_201849415 (resized).jpgPXL_20240415_201849415 (resized).jpg
#27305 43 days ago
Quoted from Mitoska:
You have peaked my interest as I have a premium also. But no issues yet.
What is the build date of your machine?
How many plays are on it?
Where did you order parts, or was it under Stern Warranty?
How much were the parts if you had to buy them?
#27306 43 days ago
Quoted from Tophervette:
March of 2022, 1 owner, maybe 1,000 plays, out of warranty. The boards were $125 each from pinball life, magnet coil $89 from Marco
#27307 43 days ago
The design on the PDB was given to their most junior EE because nobody designs a board this bad after getting a few others under their belt...
Point in case, a failure on this board can cause the high voltage interlock to NOT work... so if you reach in, its live under there folks. Seems to me this should be a no brainer to get right, but they keep having issues with this board.
#27308 43 days ago
Quoted from Gnassel:
My solution (s)
A: spring from a pen
B: created a wire gate that cover the gap.
Making a new gate, sounds easy enough and looks good. The pen spring looks flakey. I installed an MRS switch - looks cool and works every time, and there are no moving parts to fail.
#27309 43 days ago
Quoted from Sirgubster9:
The last few times I removed the glass from my 1978 Mata Hari game, I noticed how much heavier the glass is as compared to more current games. I haven't measured, but I'm sure the glass thickness must be more on the Mata Hari. When buying used glass from someone else's pb game, make sure it's the correct thickness.
#27310 42 days ago
Quoted from Bublehead:
Whats a PDB did you mean PCBA?
#27311 42 days ago
Power Distribution Board.
Also the same thing that makes clicking noises on bootup.
#27312 42 days ago
The coil winding you show appears it may have shorted over time probably due to vibration causing the varnish coating on the wire to deteriorate and the copper windings to touch each other, that causes lower resistance, and therefore a higher current draw through the driver components on the board..looks like they have been heating up a long time..the load dictates how much current is drawn. Also the driver frequency and duty cycle applied to the coil can affect the life of the winding. Maybe the coil would last longer if it were potted..perhaps getting pummeled by a high velocity metal ball accelerates the decay. Just my .02 cents.
#27313 42 days ago
Quoted from daveyvandy:
Thanks, i’m not hip to all the acronyms yet!
#27314 42 days ago
I only know it because of this amazing technical thread from pin monk:
https://pinside.com/pinball/forum/topic/stern-clicking-power-supply-fix
#27315 42 days ago
Cool I will check it out! Thanks
#27316 42 days ago
Out of curiousity, when you receive the new magnet coil, could you check the resistance of the new magnet winding and post here for reference. Thanks in advance.
#27317 42 days ago
Quoted from golfergordy:
It’s possible you had a machine with replacement leaded glass installed in the machine. Leaded glass is far cheaper and usually indistinguishable from the unleaded type unless you look carefully. It actually has a slight green tint in certain lighting conditions, and it really is 50% heavier or so.
#27318 42 days ago
I have had this happen to me Twice on my Rush Pro - PDB Failure causes the interlock to have high voltage on all the time.
#27319 41 days ago
A short while back I saw someone post how to make the "washer fix", which supposedly is better than the "business card fix" for the ball getting stuck inside the building problem. Does anyone know where I can find the details for making this washer fix?
#27320 41 days ago
In the key posts grasshopper
#27321 41 days ago
I tried that crap and didn’t work with a flip. So an another guy on here seen my post of having trouble and messaged me with how to fix it. He took a camera scope and went in the vuk to see exactly what it was doing.
What u do is take a piece of 24 gauge or so sheet metal and cut it to fit and it will cover the gap perfectly. Mine has not given one bit of problems sense. I’ll see if I can post the picture he sent me.
#27322 41 days ago
It’s in the key posts but here’s the link.
https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/316#post-7199283
It looks like folks have had various results so I’m guessing it might have to do with how large the gap is in your particular game and you have to try it to know how well it would work for you. Mine has worked 100%, not a single ball trapped since I put the washers over 1.5 years ago. At least if no luck you can easily remove the washers and try something else.
#27323 41 days ago
Code question. Is there anywhere during game play or even the videos that King Cesar is featured? He is pictured right next to the pop bumper. Maybe I haven't gotten that deep into the game, or might there be another code release.
#27324 41 days ago
Quoted from Rexdeanrds:
My Zilla has not had a working high voltage cutoff when coin door is open for nearly a year. I’ve just been enduring/coping with it. So far - knock on wood - no other obvious functional problems. But should I get PDB replaced to prevent future problems?
#27325 41 days ago
Quoted from izzy:Code question. Is there anywhere during game play or even the videos that King Cesar is featured? He is pictured right next to the pop bumper. Maybe I haven't gotten that deep into the game, or might there be another code release.
Nothing since you last asked. he is MIA and I would not expect any significant changes added to this game.
#27326 41 days ago
Quoted from Nicholastree:
Check the high-voltage interlock switch located inside the coin door. It is responsible for disabling the high voltage section when the door is opened maybe it is malfunctioning or has a bad connection. Look near where the door hinges there are some white switches.
#27327 41 days ago
I did the washer fix and have not had any issues since.
#27328 41 days ago
It is a very well known problem that the PDB could be causing this and not the interlock switch.
#27329 41 days ago
Quoted from Oneironaut:
Yeah. My pintech (an electrical engineer) took a look at the coin door wiring a few months ago and ruled that - and all other wiring problems - out. A PDB seems 90% the likely problem from what others have said.
#27330 41 days ago
I understand I am an EE and I always start troubleshooting with the easy probable causes first as a shotgun approach, then I begin a systematic breakdown starting with where the power supply starts. So if I understand the issue correctly, something on the power distribution board is shorted and bypassing the interlock switch?
I have only been into pinball for about a year, so I don’t know all the history and common issues with all of the games but enjoy learning.
#27331 40 days ago
I have this issue as well and have been contemplating buying a new PDB from pinballlife. But I don’t want to replace it only to have it happen again. Was this just a bad batch of boards or are they all just prone to failure in this way? Anyone know?
#27332 40 days ago
Got this cool 3D printed Godzilla head (which my artsy daughter painted for me). Will be the centrepiece for my topper........
#27333 40 days ago
Odd question, but when does the spotlight post (next to the Maser target) and pointed towards the building turn on? Went through the GI and Flasher tests and can't seem to figure out if it works and when it is used during gameplay.
#27334 40 days ago
There appear to be two versions of the PDB in the backbox. 99.9% of all machines ship with a PDB that includes the coin-door cut-out logic. Very useful when servicing a coin-op machine on-site. BUT, there is a second version of the same board, looks nearly identical, but the upper corner is missing most of the parts. The pads are there, but the components were never populated. This little brother was intended to be used in Home Pin machines, which did not have a coin-door interlock requirements, and there has been at least ONE report of these PDBs accidently finding their was into production machines. Check your board in the backbox to confirm it is in fact the proper 520-8096-00A board with all parts installed.
#27335 40 days ago
Just received my premium last Tuesday and am in the process of dialing the machine in. Any recommended out-of-the-box adjustments or tweaks to this game? I've only played 10 or so games so far but seems a bit unforgiving compared to some of my other pins.
#27336 40 days ago
Quoted from CookyJar:
It doesn't come on in flasher test? It's on persistantly during normal gameplay, and may occasionally flash. But push the start button and it should be on.
#27337 40 days ago
Quoted from Markharris2000:
The PDB on the home pin is a bit different. They likely came from Guardians, which didn’t have an interlock switch.
#27338 40 days ago
Just joined the club today. Only 119 total plays. Super excited
#27339 40 days ago
Quoted from Sorokyl:
Now that I know it's supposed to be on most of the time, that was super helpful.
Turned out the bulb just had to be reseated, then it came right on.
#27340 40 days ago
Quoted from MoSeS_1592:
Check all leveling angles. Apparently this game is finicky.
My seems a little unforgiving too, but I toss that up to my poor pinball abilities...
#27341 40 days ago
Looking for a GZ Prem in the Chicago area if someone is looking for a change.
#27342 40 days ago
Quoted from iamabearsfan:
Pinball pro has new ones. I bought a game from him and I was able to pick it up in Glendale Heights and avoid shipping costs.
#27343 40 days ago
If you want new, there are a few sellers here in the Market with NIB for $9500 with free shipping.
#27344 40 days ago
Thx
#27345 39 days ago
My wife found a new T-shirt for me today despite my standing order of no more Ts (I have way too many). I made an exception
IMG_0935 (resized).jpgIMG_0935 (resized).jpgIMG_0936 (resized).jpgIMG_0936 (resized).jpg
#27346 39 days ago
A bit off topic, but last Tuesday my very first new in box pin arrived. It's a Godzilla Premium. I noticed in the menu settings a burn in option. Should I do it?
#27347 39 days ago
I recommend you play 25 games... That's your Burn-In! Seriously, the Burn-In option is mostly for Operators to make sure the machine is working before they place a machine on-site. For Home Use, you will be the burn-in yourself when you play it. Anything goes wrong, you can fix it without driving out to the location.
#27348 39 days ago
Thanks for the clarification.
#27349 38 days ago
I thought that burn in option was for when you were tired of it, and it would burn up. Kind of like that thermite grenade on top of the Intel computers in the war zone.
#27350 38 days ago
Quoted from badfish981:Easy process to replace the T molding?
Just replaced my t-molding on my avatar (sam) super easy. Just take a measurement of your old tmolding after peeling it out. Be careful not to pull or chip the wood. Just go slow. The spike 2 system has them wrap around to the back. Keep the seam/ends at the back so you don't see It. I think tmolding.com is where I got mine. Cheap but expensive shipping so stock up
17,000 (Firm)
Loveland, CO
$ 14.95
Pinball Pimp
$ 50.00
Chrome Candy
$ 575.00
Gameroom Bling
$ 200.00
Cabinet - (Alt) Translites
PINBALLPICKERS
Filament Printing
€ 40.00
Pino Pinball Mods Shop
$ 29.00
ScottieIA Mods
$ 34.95
Discos Pinball Mod Shop
14,000 (Firm)
West Fargo, ND
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 45.00
Chrome Candy
Game Room Info Shop
$ 320.00
Diddy's Pinball Mods
5,500 (Firm)
Land O' Lakes, FL
$ 80.00
Lighting - Backbox
arcade-cabinets.com
Paradise Distribution
$ 125.00
$ 80.00
Pin Monk
$ 185.00
Raiden Mods
$ 29.99
Cento Creations
Daddio's 3D Printed Mods
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/547 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
