Quoted from KneeKickLou:Yeah put it in switch test mode then you can start poking around and see if the switch actually registers when you push in the slingshot.
If the coin door is open all the high power stuff gets disabled so you should be good there.
If it doesn’t register you might have to lift up the playfield to see if there is a loose wire or broken connection on the slingshot.
Remember to take the balls out before you lift the playfield or they will be flying all over. I did that one of my first times lol.
Ok I have an update! I put it into test mode on the screen it didn’t say anything is open or closed when I tapped the slingshot and switches and nothing happened :
So then i stretched the rubber band out more and then the switches started registering; So maybe only adjustment I need to make Is stretch the band out a bit more ? ;
When I stretched the rubber band it must have released from being closed …
What do I need to do next guys?
Maybe use a flathead to make sure there is a larger gap in between switches? Is this most likely my issue?
I guess it’s good news I temporarily got it registering!
I feel like we are almost home! I’m getting excited
Thank you all for being patient
