(Topic ID: 300354)
Stern Godzilla Official Owners Club King Elwin
By beltking
2 years ago
  • 27,338 posts
  • 1,641 Pinsiders participating
  • Latest reply 25 minutes ago by bicyclenut
  • Topic is favorited by 1,026 Pinsiders
Topic poll
“What model did you order?”
  • PRO 284 votes
    20%
  • PREMIUM 893 votes
    63%
  • LIMITED EDITION!!! 243 votes
    17%
(1420 votes)
25 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27,338 posts in this topic. You are on page 298 of 547.
#14851 1 year ago
Quoted from ChipScott:
Question for those who have installed Stumblor's (Davey's) scoop sign.
Got it installed and it looks amazing and everything works perfectly fine.
Question is: there's an additional wire that can be used to link into the GI such that when GI goes off, the sign also goes off (or dims?, not sure). Anyway, sounds like this is an additional feature that can be implemented on this mod and I'm wondering if anyone has done this yet and if they prefer it to the sign being on all the time (or vice versa).
Looks like that’s part of the most recent firmware update?
https://pinside.com/pinball/forum/topic/godzilla-tokyo-neon-sign-mod/page/17#post-7116094
#14852 1 year ago
Question about playfield pitch. Finally got a digital level and it reads 6.8 at the building, but only 6.2 at the flippers. Should it be 6.8 at the flippers too?
#14853 1 year ago
Quoted from jackd104:
Thanks for the tip. I just did this. Haven’t played yet but clearly I widened the left ramp shot by a couple of mm (which is significant in pinball!)
Here’s a pic of the nut to loosen and what my balls guides look like after adjustment. Just loosen the nut, then press on the front of the ball guide in toward the magnet as you tighten. You can do the same to the nearby wallop shot using the nut up and to the right. Basically these are the two ball guides to the left and right of the magma grab[quoted image][quoted image][quoted image]
Report back after you play a few games! The left ramp should be a lot more flowy. I even hit it by ACCIDENT sometimes.
#14854 1 year ago
Quoted from tbaum:
6.5 at the flippers (or whatever you're going for). Just measure down there. The playfield isn't going to be dead perfectly flat
#14855 1 year ago
Quoted from tbaum:
Same issue, so I decided to split the difference and I do 6.5 at the center of the PF. I think it's a personal preference for how you like the game to play.
#14856 1 year ago
You can certainly do this, your mod should have come with a bulb socket adapter that is meant to go onto a GI bulb on the back, run a wire to the back of the sign. Then in the GUi for configuring the sign, you can enable this feature. It should be in the instructions. If not ask Davey.. I like this feature a lot.
#14857 1 year ago
Thanks for your responses.
Yes, there is a setting on the back of the sign where you just need to move a connector and then attach a matrix wire and send it down to a GI bulb (and that allows the dimming/off when the GI goes off as opposed to constant on).
I was given all of these components with my package (which was very handsomely packaged I might add...thx again, Davey).
Really just looking for a vote as to what people thought about constant on vs. dim/off with GI off.
Sounds like you like the feature of it going off with the GI. I haven't tried that setting yet, but it seems pretty straightforward.
By the way (and not to jump on any one or another creators bandwagons), but today I also took the opportunity to install Doug's flaming speaker light kits. I'd never seen them in person and Oh $h#t these things are bad to the damn bone! I mean wow man...I knew they'd be cool, but these things are absolutely badass!!!
#14858 1 year ago
Hoping to FINALLY get mine installed this weekend. Had them for months, but my pin arrived only a few weeks ago. Can't wait...
#14859 1 year ago
Quoted from Bohdi:
Same here. They've been sitting down in the game room for about a month, finally had some time to install them today. I had to undo and redo those little micro screws that go into the monitor a couple times over just to get everything right, not that the online instructions weren't good, there was just a couple little steps that I had to stumble over, lol.
They look SO cool. Hats off!!
#14860 1 year ago
Is there also a Youtube video on the install, or just the online instructions? I used the online instructions on my IMDN, but I prefer a video when available
#14861 1 year ago
Quoted from Bohdi:
www speakerlightkits.com.
Site comes up, choose the "manuals" tab there on the left. There's a "flaming flames" icon that pops up (along with the other manuals) and just click that and you're off to the races.
Btw, and on a nother note...I did the light sensor addition to the Tokyo Sign mod (to dim/turn off when GI turns off), and I think I like that result
#14862 1 year ago
Yep there is a jumper in the back that needs to be moved from off to on position. In addition I believe the red side of the two wire plug goes on the TX pin on the back of the sign. ( Only the one wire as the other is free off the pin)
Now what I had discovered, when you boot the game the sign will power as normal and dim as normal with a slight delay but works awesome. However if you went into the game settings and adjusted the LED from lets say 100% to like 60% , and the brightness I believe from 255 to like 200. I found when the game called for it's firs dimming effect the sign would dim as normal but not restore when the GI's come back on. Once I changed the settings of the LED inserts and GI brightness back to 100% and 255 (default) All was good once again.
Just something to know before you or someone else may encounter this and start pulling hair out or make Davey pulls his out lol.
#14863 1 year ago
Quoted from DeathHimself:
Now what I had discovered, when you boot the game the sign will power as normal and dim as normal with a slight delay but works awesome. However if you went into the game settings and adjusted the LED from lets say 100% to like 60% , and the brightness I believe from 255 to like 200. I found when the game called for it's firs dimming effect the sign would dim as normal but not restore when the GI's come back on. Once I changed the settings of the LED inserts and brightness back to 100% and 255 (default) All was good once again.
Thanks for the excellent pointers!!
I can see how dimming the GI a bit might negatively affect the sensor, so appreciate that advice!
#14864 1 year ago
Thx for your reply.
I agree. It's kind of fun on all the time (especially since it's different lighting sequences continues at all times), and especially since it's a "mock" neon sign... I mean, at night when the lights of businesses go out, you'll still see neon signs flickering about in the city, so there is a somewhat realistic benefit to having it on all the time.
Curious for additional votes/impressions out there on the subject.
I would recommend connecting the GI dimming cable as there is a setting in the software where you can set the dimming to your liking. So if you dont like the sign to go off completely, you can set it to any brightness level between off and full brightness during GI dimming. I did not like the sign to fade off as i missed the insert information. But i like the sign to adapt to GI brightness
#14865 1 year ago
Quoted from Rdoyle1978:
Just tried it out and had a very good game, 2.3B. I was playing well today so I don’t attribute it entirely to the adjustment. But the shot did feel more open and the game flowed better. Cheers.
#14866 1 year ago
I got this also....diverts balls to the left flipper...no more STDM like I was getting every time.
#14867 1 year ago
I picked up an extra Mechagodzilla from Pinball Life for my premium. I can picture an airball breaking the arm someday, better safe than sorry. It seems like they're already sold out.
https://www.pinballlife.com/mechagodzilla-figure.html
#14868 1 year ago
I'm sure this has happened to me before, and I just never noticed: Hitting two balls perfectly during multiball so each hits a different ramp and crosses at the building in the center at the same time.
It looked really cool!
#14869 1 year ago
Our Computers Detect Coin in Pocket.
#14870 1 year ago
Had a ball get stuck in the building last night as it was moving after I qualified for Monster Zero. It came out of the scoop after I selected that powerup directly to my left flipper as I shot it up into the building and it got stuck since the building was moving and the building stopped moving mid-level. After ball search happened and all the coils fired, the building moved up and the ball came out.
There's a reason the balls drain STDM after godzilla multiball is activated and the building is moving. Elwin himself even stated that, in this thread. But to each their own.
#14871 1 year ago
Part 1 of the “How to get to Planet X” strategy has been released. Now that you have your billion point score, let’s take you to Planet X! Link is below.
https://pinside.com/pinball/forum/topic/how-to-score-a-billion-on-godzilla-and-more/page/4#post-7142483
#14872 1 year ago
Quoted from chuckwurt:
You have to survive the whole mode. It’s very long. And no shots during that work you towards anything else in the game.
Starts on the left ramp and goes around all the major shots on the playfield. They are all on a 10-15 second timer. Very hard to survive to the end of that mode.
I disagree! You can start Tesla before starting rampage and it will carryover. As for surviving, I agree it can be challenging. If the goal is to survive, then right ramp ski jump is the technique to use. If the ski jump is hard, then right ramp to left ramp. If you miss, then be slightly early and clip the magna post on the left. Ignore the left spinner shot on rampage if you want to survive.
#14873 1 year ago
Quoted from troon47:
If they were going sdtm probably check your playfield level even if you've inst
Quoted from purbeast:
That may be the intent but out of 1000 games played I have had very very few GZ multiball with triple drain. Usually I can save all 3 if the game is properly leveled. At least two.. and even rarer in those 1000 games had it caused any weird issue..
The fact of the matter is that you get more ball save time if you don't triple drain, and it feels "less bad" especially for casual people who don't know who designed the game and don't give a shit what they intended, or why. They just are trying to keep the ball from draining
I will say properly leveled games don't need a mod to prevent it. But I completely understand anyone that wants to install one
#14874 1 year ago
Quoted from Nokoro:
Even more fun is two immediate shots to the same ramp, love seeing both balls coming down the habitrail together!
#14875 1 year ago
Quoted from Sorokyl:
A properly leveled game is supposed to drain stdm on Godzilla multiball. If it's not doing that, then your game isn't properly leveled.
Again, Elwin himself has said, in this thread, it is supposed to do that.
https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/128#post-6718166
#14876 1 year ago
I heard him say in this interview that the balls should hit the tip of left flipper if you hold it up when the balls drop down. He has also said level the game left-to-right putting your level in front of the building. I have done this very carefully with a digital level and my game behaves exactly like this. If I hold the left flipper up, most of the time no balls drain. Rarely one ball drains. Never seen 2 or more drain.
Start at time 35:05
#14877 1 year ago
Start at time 35:05
Exactly. Usually for me the first ball hits tip of left flipper, and that knocks the others away from drain
#14878 1 year ago
Posted this in the mod thread too. Got my speaker lights and installed, along with a Godzilla and King Ghidora plastic silhouettes I cut out. Looks awesome!
F34732DD-C98E-438A-8465-FBE0F92B17E3 (resized).jpegF34732DD-C98E-438A-8465-FBE0F92B17E3 (resized).jpeg03FF0FDB-8596-46F9-B20F-30DDAA77F732 (resized).jpeg03FF0FDB-8596-46F9-B20F-30DDAA77F732 (resized).jpeg9FDEF99F-1132-4F6C-9EC6-147C580FFA64 (resized).jpeg9FDEF99F-1132-4F6C-9EC6-147C580FFA64 (resized).jpeg
#14879 1 year ago
Start at time 35:05
Yeah interesting to hear that. But basically it's not supposed to be going back directly to a flipper to be able to get a clean shot to a ramp while the building is moving.
#14880 1 year ago
I'm still having this problem where the mechagodzilla spinner randomly rotates left to right for a little bit. It'll stop for a while then rinse repeat all throughout the game. I know a few others have reported this as well, has anyone figured out a fix??
I really think it's code related since I didn't have this problem before the latest code update, but I do know others reported having it the whole time.
#14881 1 year ago
Quoted from ZoraShinoda:
Seems like the machine does not know its position at times so it tries to bring it back to where it belongs. Could be the connector or the position switch of the mech (opto maybe?).
#14882 1 year ago
Quoted from Tomass:
Interesting thought, I'll look in the manual to see what parts are involved
#14883 1 year ago
Quoted from Beyndtstng:
Check this video out starting at 32:00. All about annihilation and carnage bonus. I go into detail on both.
This video is great! Deep dive into Annihilation Bonus. Do not switch Cities. This is were the big points are. He gets a 707 Million Carnage Bonus
#14884 1 year ago
There should be a switch to set each position. It would then rotate until the switch triggers. If the connection is lost it thinks it moved out of position and tries to move it back. Most of my tech experience is in older games, but that is how they work. Not sure if it is a microswitch or opto on GZ though.
#14885 1 year ago
So looking for a little bit of help here.
I just installed the clear pop bumper. I shaved down the tip of it so that it was virtually the same exact size as the white one that I replaced. I was putting them basically tip to tip so they touched the underside of eachother and were nearly identical.
However after putting everything back together, the saucer coil is not firing when the clear bumper is hit. I have tried with my fingers and stuff and it's simply not firing at all.
If I do the coil test however, it fires no problem.
Anyone know what I have messed up? Could it be that the tip of the clear one is still just a bit too long and the leaf switch is closed so it's just not firing when it's being depressed? If that is the case I wasn't sure if the coil test would fire or not.
Any help is appreciated. Thanks.
#14886 1 year ago
My Mecha ramp rotates back and forth non stop during all my games, and sometimes for no reason while in attract mode. I've been talking to Stern about it after trying a few things with my distro's tech, and they think it might be the sensor board. I'm waiting to receive it, but I'm not looking forward to disassembling the bottom part of the Mecha shield to change it. Really hope that will fix it, my game is really hard to play with no shot to the ramp or spinner.
#14887 1 year ago
Adjust the switch to have less gap. If you push the switch with your finger from the underside of the pf it should fire. Lift the playfield and see how much gap is in the switch.
#14888 1 year ago
Quoted from Tomass:
I think the problem is that the switch is actually depressed the whole time because there is no gap between any of the leaves on the switch. When I look at the leaf switch for the flippers the gap is obvious. Attached is a pic of how it is at resting position.
#14889 1 year ago
Quoted from bloodonthepins:
Has your Mecha been like this from day 1? Do you know what code version came with your game?
#14890 1 year ago
I had the same issue after changing mine out. You can just slightly bend the switch to create a very small gap. Press on the clear skirt from the top side while looking at the switch underneath to make sure it connects when pressed.
#14891 1 year ago
my right side sling is firing off now and then for no reason
#14892 1 year ago
Quoted from Cwells3290:
So yeah the problem was definitely that the switch was making contact the whole time but now I'm even more confused.
I took it apart again and then I put the normal white one back and tightened the screws. However after I did that, even with the one that came, the switch was being depressed when I had everything screwed tightly down.
The only way to get it to work properly was basically to loosen the screws holding it to the base, making the spring push up the ring that the ball hits a bit more so that the switch isn't depressed. However now the whole pop bumper is "loose" in the sense that it's not tight and every time you hit it, the whole thing moves around a little since it's not screwed all the way down.
I don't know how when I installed the normal white one back, it was now doing this. I am guessing maybe I did something wrong when putting it back together? I'm starting to wonder if maybe I have the part that goes right on the playfield, turned 90 degrees the wrong way, because 2 of the holes are raised a bit and 2 aren't. Maybe that little extra space is causing this issue.
Either way I'm done messing with it tonight because I'm tired of soldering this crap lol.
#14893 1 year ago
Quoted from Jamesays:
Do you happen to have any kind of star post lights or anything like that?
I had that problem with my JP and it ended up being the wire that was going from the star post light was causing the switch to trigger because the light had rotated a little bit.
#14894 1 year ago
no its stock only added plastic protectors
CBF88926-5784-4B94-B652-75522422AEBC (resized).jpegCBF88926-5784-4B94-B652-75522422AEBC (resized).jpeg
#14895 1 year ago
From that pic it looks like you actually do have star post lights. Your slingshots are glowing.
#14896 1 year ago
Making Progress! My first time winning all 4 cities, but I didn't make it to the last Tier 2 battle.
Along with my new high score of 8.2 Billion, I picked up a few more bests for me so far including a 781M Destruction Jackpot!
IMG_3287 (resized).JPGIMG_3287 (resized).JPGIMG_3290 (resized).JPGIMG_3290 (resized).JPGIMG_3295 (resized).JPGIMG_3295 (resized).JPGIMG_3296 (resized).JPGIMG_3296 (resized).JPGIMG_3299 (resized).JPGIMG_3299 (resized).JPG
#14897 1 year ago
Does anyone know if Godzilla will be receiving Co-op and the difficulty modes (like in Mando)?
It would be amazing if these features were standard across all Sterns.
#14898 1 year ago
Quoted from Had:
It will not. I give Bond a better shot at having that it's a Dwight thing the game coder.
#14899 1 year ago
The Mecha shield was fine when I got the game on code 0.96. The issue started happening sightly during next next code upgrade (but not immediately with code 0.97) and just kept getting worse and worse. Still happening with most current code.
#14900 1 year ago
So I did have it installed properly but the skirt tip was just too long still and it was keeping the switch always activated.
I ended up shaving the tip of the skirt even more until I got it just perfect. Took some time and trial and error until I got it perfect, but now I got everything in there and it's working great and looks fantastic!
Got some more comparison pics at the link below:
https://imgur.com/a/PKRDL6F
IMG_8458 (resized).JPGIMG_8458 (resized).JPGIMG_8459 (resized).JPGIMG_8459 (resized).JPG
$ 55.00
Gov's Mods
11,000 (OBO)
Mount Pleasant, WI
$ 320.00
Diddy's Pinball Mods
9,150
Potomac, MD
$ 210.00
Trade
Machine - For Trade
Chula Vista, CA
Slipstream Mod Shop
€ 168.00
Lighting - Backbox
Watssapen shop
$ 75.00
JuanSolo's modshop
$ 80.00
Reflex Mods
9,250 (OBO)
Gilroy, CA
$ 29.99
Cento Creations
€ 110.00
Pino Pinball Mods Shop
$ 69.99
Inscribed Solutions
$ 120.00
Dijohn
Lighting - Backbox
Myth Pinball Parts Shop
GMods
BomberMods
$ 19.99
FlipMods
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 45.00
HurryUpPinball
€ 178.00
Lighting - Backbox
Watssapen shop
$ 73.99
Cento Creations
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/298 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
