I got a couple questions about leveling my pin. I've been playing it since I got it 2 weeks ago with the threads on the levels just matched to my JP until I had a chance to check it today. I checked it today and need to fix the pitch and the angle down by the flippers was 6.3%.
1. Is the angle you want (6.5 in this case) supposed to be at the flippers? Or in the middle of the play field? I know when I measure the top vs. the flippers it is not identical. It is steeper up top. I also remember this happening in my JP however I don't recall the exact answer to this.
2. I also have the same question about the pitch - where do you want to measure that? Ideally it should be throughout the whole PF but if it's not possible to get it 0 all the way through, is down by the flippers the right spot?
3. I am having trouble lifting my pin because of the current way it sits and there just isn't much room behind/around it. What is the best way to go about lifting it up so I can adjust the leg levelers? Like am I going to have to slide it out, lift and adjust, then slide it back? Or is there some other trick that you all use to level pins that have a pin right next to it where the backs are up against the wall?
