Quoted from RTS:Don't you know people here get really upset if anyone comments on the awful wait time for Doug's speaker light kits?
At least you made sure to be really polite to Doug for his shitty wait time so he wouldn't get upset with you.
For those who say the wait is worth it, it ain't. Myth pinball has the same excellent product without the bullshit delay.
https://www.mythpinball.com/game/
Concerning the flame effect, to anyone saying the two light kits look the same....I'll come out and call BS.
The main difference, in my opinion, is the light frame on the Myth kit is built so the light strips are visible all the way around the rectangle honeycomb grill area. This draws your eye to the light strips themselves and distracts from the light that the light strips are putting off toward the middle of the grill area. I believe this is what makes them look like lit up flaming "U" shapes that others have pointed out. Of course, it could also be lower quality light strips, but I expect it's more likely the frame design. In any case, what I know is they do not look the same as my light kits, as you keep repeatably claiming.
Quoted from RTS:Gotcha. Myth speakers still have independent random flames so I didn't see the difference.
The biggest difference (other than the delay) is the optional building overlay. They are not the same.
Doug's are a sillhouette that can block the bottom row of lights a bit as he points out on his website. Myth has larger buildings that are more transparent. If you cut off the outer frame border, the light is even better. Both are good - just a matter of preference
As for their building design, I didn't realize the frame of it went into the visible honeycomb grill area to cover up the frame's visible light strips. I guess that's one way to try to correct the strips being in direct view. It's easy to understand why I didn't know that, because no one will post a video or even a picture of them mounted in a game or behind a speaker panel. Why is that? Seems weird. How about a picture of them mounted in a game, or even just mounted on a speaker panel, from a player's distance away? It doesn't seem too much to ask. I would like to see what they actually look like in use.
Quoted from RTS:Have to disagree with you there, unless you just don't like speaker lights.
I've had both kits on my games. Indistinguishable. They are so totally not meh.
So, let's see a video of the Myth light kit flames, actually mounted on a SPIKE 2 speaker panel, from a player's distance away, looking the same as mine. Use the foam or "Light Distibution Panels" or whatever you need to show off how they look exactly the same as my light kit as you keep claiming. You say they are indistinguishable from each other, but from what I have seen...they just don't look as good when it comes to the flame effect.
To the people that have ordered or are looking to order from me, I'm sorry they are taking as long as they do to make. I can't really argue that, but what I can do is ask for proof of them looking the same or as good when the same people keep bashing me over and over again and claiming you can't tell the difference between the two when the difference is obvious. If you want the best flame effect in your SPIKE 2 speaker panel....put in your order with me and prepare for a wait. Your business would be appreciated. If you want a flame effect that is almost as good and you want it right away...get one of the other flame kits. You should check out Cointaker's flaming failure....it's a downright pathetic attempt.
Doug (SpeakerLightKits.com)
