For those that are modding their pop bumper to a clear body, be aware of the following (most of you know this, but there's a few newer hobbiest here that may not have restoration experience):
The clear bumper skirt I was supplied is too-long compared to stock (see pic). As you need to remove the RGB light to work on this, you'd be bummed to discover this fact after you reassemble everything. Let's get it right the first time, during your install:
You need to VERY carefully shorten the actuator on the clear bumper skirt. [Note: shortening is considerably easier than re-gapping the spoon switch on the bumper. Spoon switches are notoriously finicky, and it takes careful work and the right gapping tools to do that job properly; best to avoid it if possible. You can screw up a spoon switch pretty easily if you don't know what you're doing]
The amount of shortening needed is tiny. I'd suggest ever-so-slightly filing/sanding the tip to a rounded end. I used a hobby belt sander; hand sanding or filing will work if you're careful. Reinstall with the body and base, screw it down, and go into the switch test. Confirm operation (off in neutral; on when the skirt is slightly depressed). Better to have the switch constantly on when you start, with the post too-long. Remove, sand/file off a tiny bit(I mean TINY), and reinstall. Repeat this until you have reliable operation.
The clear body looks great, a fine mod to those that suggested it, above. Good luck.
