(Topic ID: 300354)
Stern Godzilla Official Owners Club King Elwin
By beltking
2 years ago
  • 27,299 posts
  • 1,639 Pinsiders participating
  • Latest reply 40 minutes ago by tscottn
  • Topic is favorited by 1,027 Pinsiders
Topic poll
“What model did you order?”
  • PRO 284 votes
    20%
  • PREMIUM 892 votes
    63%
  • LIMITED EDITION!!! 242 votes
    17%
(1418 votes)
25 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 27,299 posts in this topic. You are on page 177 of 546.
#8801 2 years ago
From pinball life…
Spring tension from lowest to highest:
Blue (266-5001-05)
Green (266-5001-04)
Standard (10-148-1)
Orange (266-5001-07)
Purple (266-5001)
Gray/Silver (266-5001-14)
Red (10-148-2)
#8802 2 years ago
i will say, there really shouldn't be a difference between the standard and mothra shooters...check your alignment on where the tip matches with the ball, that your tip cover is sat on correctly, etc.
#8803 2 years ago
Stupid question...is Stern still not including the good rails on Premiums and still putting pegs on there?
#8804 2 years ago
Quoted from Jamesays:
I apologize,I misspoke In Godzilla I have only added pinwoofers Do it yourself amp and an external polk sub.It sounds great and I didnt feel the need to upgrade the other speakers.
Is the Polk sub not powered on its own like the one most people get and the reason for the amp?
#8805 2 years ago
Quoted from Puffdanny:
yes its a powered sub,Pinwoofer could better explain the amp
#8806 2 years ago
Quoted from Pugster:
Awesome info in this thread:
https://pinside.com/pinball/forum/topic/improving-sound-quality-the-diy-route
I’m going with Kicker 5.25’s and an 8” sub.
+1 to this thread.
You can build a better sound system than pinwoofer provides for around $100. Versus the $450 set that pinwoofer sells.
An External powered sub is still the best bang for your buck IMO.
#8807 2 years ago
Quoted from jonnyqtrek:
There was a thread on here somewhere about spring colors... If memory serves, from weakest to strongest was blue, green, red, purple; can someone confirm?
Copied from the PinballLife website. Just look up shooter spring on their site and they’re there.
Blue (266-5001-05)
Green (266-5001-04)
Standard (10-148-1)
Purple (266-5001)
Red (10-148-2)
#8808 2 years ago
Quoted from Frax:
I thought Stern stopped using those horrid pegs a while ago.
My JP Pro and my buddy's GZ Premium definitely both have the traditional style sliding rails.
RussM
#8809 2 years ago
Quoted from Frax:
Guardians was the last pro to use pegs
Thank you keith elwin
#8810 2 years ago
Quoted from JSC:
Anyone get the egg shooter rod and find it to be too weak? Mine struggles to make it to the skill shot. I tried swapping the spring to the one from the standard shooting rod and didn’t do anything. Both are green color…I know you can buy different colored springs from pinballife, but not sure which one would be stronger.
I had the same issue with my Mando when I swapped out shooter rods. I went with the red spring and it fixed the issue.
#8811 2 years ago
Quoted from Muymanwell:
I actually have the same problem. Both are green so I didn't bother with it. I can't see how you could install it wrong. It's only 3 screws. As far as the rod is concerned not very nice for the money but the only one that was is JP.
#8812 2 years ago
Quoted from sushko:
I didn’t install it wrong…it feels considerably weaker uninstalled just pulling it back. Not sure why.
#8813 2 years ago
I’m ready.
6584CCA7-15D5-4C86-AE9D-02BBA2B648F8 (resized).jpeg6584CCA7-15D5-4C86-AE9D-02BBA2B648F8 (resized).jpeg
#8814 2 years ago
Quoted from JSC:
Look at changing the barrel spring on the OUTSIDE of the cabinet. If you get a shorter one, the tip will make better contact with the ball. It's often the problem.
#8815 2 years ago
Quoted from flynnibus:If your mechzilla goes Alien mode.. don't wait. Get to the screw before the mech comes apart.
Here's the setup.. the pan head screw holding the magnet can work free.
It's kind of a PITA because that spring washer doesn't fit through the plastic shell easily, so if it escapes the magnet pole.. it's a PITA to get on the magnet, through the hole, and aligned with the coil at once. I had pulled it out, bent it a bit narrower.. and by not aligning it with the coil, I was able to get it halfway through the hole, and force it through with the magnet pole... then get it in the coil.
But note when trying to put the screw back in, you have to lift the coil (it's otherwise not supported) up some to get a nice squared fit for the screw. You can't hold the magnet to keep it from spinning either, but the spring washer is there I think to help get that tension for you. Recommend putting some locktite on the screw when you re-install it.
Probably easier if you took the mech off completely, but I didn't see an easy way to get to the screws holding mechzilla on.
This just happened to mine but the damn magnet core fell outta the belly! So this means the screw and washer are who knows where! Gotta get in there and find em tonight.
#8816 2 years ago
Quoted from MUGEN_4_LIFE:
The coilstops that stern use are coil
Common parts, so not a huge deal. But good news is you know they in there… so just shakem out if you need to
#8817 2 years ago
Quoted from JSC:
Yes I have noticed the same thing upon installation. However after about 20 games I am hitting the super secret skill shot more consistently than ever. It is definitely not as strong as the previous shooter rod for whatever reason but I'm not complaining too much yet with all the skill shots I'm hitting now.
#8818 2 years ago
It’s because you changed the spring or installed it incorrectly and the shooter tip is sitting in the incorrect position when it strikes the ball.
#8819 2 years ago
Weak new shooter rod could also be the weight of the new handle being lighter than stock. Might need to use a stronger spring
#8820 2 years ago
Quoted from chuckwurt:
This. Experienced similar with my TMNT. Carefully ensured ball is being struck dead center by the plunger and suddenly it got its mojo back.
#8821 2 years ago
I’ve been waiting to play GZ till I get mine. I’m probably going to give in to playing it this weekend at TPF…… I can’t hold out any longer
#8822 2 years ago
Karl's streaming Godzilla now. Last time was over 30 billion...
https://www.twitch.tv/iepinball
EDIT: He got one of the "impossible" secret combos early on:
https://clips.twitch.tv/SilkyBovineBatTinyFace-vgfnB8FXu9TJBjXt
#8823 2 years ago
to close a conversation from the last time karl streamed, he does have his scoop kickout set to factory
#8824 2 years ago
it’s absolutely not this. The rod uninstalled feels significantly less tense then the stock uninstalled. Maybe I just got a bad one.
#8825 2 years ago
Quoted from PinMonk:
I wasn't able to find a shorter one so I ended up asking a friend with a greater tool set than me to trim the spring on both sides... That worked for me, if anybody has a source for shorter barrel springs, it'd be great to have a spare or two...
#8826 2 years ago
Quoted from JSC:
Then it has the wrong spring on it. Put the spring from the stock rod on it.
If the springs are different colors, that means they are different strengths.
#8827 2 years ago
Yea ive had to do this on a few of the optional upgraded rods. Just swap them
#8828 2 years ago
I installed the new rod over the weekend and mine is so much smoother then the original. No idea why, doesn't make any sense to me; but really happy with it.
#8829 2 years ago
Just joined with a 3 month old Premium, happy to be in the club.
My first question is the upper flipper. It doesn't seem to have the same power as my upper flipper in JP, and wondering if that is a normal feel for this particular flipper. Coil stop is fine, as I know that would be the first thing to check.
#8830 2 years ago
Quoted from jedi42:
Look at the flipper button setup in the cabinet check your gap spacing. Just one variable to eliminate.
#8831 2 years ago
Quoted from jedi42:
That's the normal feel compared to JP.
#8832 2 years ago
Quoted from jedi42:
Congrats! Still waiting on mine to arrive.
You can also change flipper strength in settings.
#8833 2 years ago
Quoted from jedi42:
Check the coil power settings to see if the previous owner lowered the power down from default.
#8834 2 years ago
Quoted from awesome1:
You are lucky, i pre ordered a GZ premium the day one when it was annonced, normally the delivery would be in november, then in february, then in Mars, now, maybe in November...
A bit frustrating....
Already played in a Pro to see how the game goes, it goes amazing, can't wait to get mine, if i get it... :/
#8835 2 years ago
New code! New code just dropped!!
And I am out of town. Great.
#8836 2 years ago
Godzilla power ups!!!! OMG!!!!
#8837 2 years ago
V0.93.0 - March, 22th, 2022
- Godzilla Powerup - Powerup Meter added to UI to track the collected powerups, yellow arrows indicate the threshold to light it at the scoop
- Godzilla Powerup - Level 1 choices picked at random (same for all players) unless it's a competition game in which case uses the first one
- Level Summary:
- Level 1 (2) - LEFT - - RIGHT -
GODZILLA MB BASE JACKPOT +250K MECHAGODZILLA MB BASE JACKPOT +500K
LIGHT HEAT RAY SKILL SHOT +1X MULTIPLIER
15M POINTS LOOP VALUE +250K
DESTROY SAUCER SAUCER VALUE +500K
JET FIGHTER ATTACK VALUES +250K COLLECT BONUS
- Level 2 (3) - LEFT - - RIGHT -
TIER 1 BATTLE TIMERS +10 SECONDS TIER 1 BATTLE TIME BONUS +5X
- Level 3 (4) - LEFT - - RIGHT -
DESTRUCTION JACKPOT +3 SECONDS TIER 2 BATTLE TIMERS +10 SECONDS
- Level 4 (6) - LEFT - - RIGHT -
SAUCER ATTACK +3 SECONDS RAGE COMBO +3 SECONDS
- Level 5 (6) - LEFT - - RIGHT -
50M POINTS / PLACEHOLDER 50M POINTS / PLACEHOLDER
- Level 6 (6) - LEFT - - RIGHT -
RODAN TIMER +15 SECONDS MAGNA GRAB 2X
- Level 7 (6) - LEFT - - RIGHT -
SUPER SPINNER 2X LOOP VALUE 2X
- Level 8 (6) - LEFT - - RIGHT -
DESTRUCTION JACKPOT +2X LIGHT ALL ALLIES
- Level 9 (6) - LEFT - - RIGHT -
COLLECT BONUS COLLECT IMPOSTER
- No more powerups will light after Level 9 for now
- Godzilla Powerup - changed the list of increments to the powerup meter:
- 3 Trains +2;
- Tesla Strike Successful Finish +2
- Bridge Attack MB Start +1
- Megalon and Gigan Super +1
- Tier 1 Monster Defeat initial +2 / replay +1
- Loops +1 or +3
- City Combo +1
- Monster Rampage Start +2
- Enter New City +1
- Saucer Attack MB Start +2
- Tank Attack MB Start +1
- Destruction Jackpot +1
- Tail Whip Award +2
- Powerline Attack Start +1
- Godzilla MB Super +1
- Mechagodzilla MB Start +1
- 5 Secret Combos +2
- Super Spinner Rip +1
- Super Secret Skill Shot +2
- Maser Mystery +1
- First City Under Control +2 (in addition to the ones you get for Tier1 Monster defeat)
- Jet Fighter Attack Start +1
- Jet Fighter Attack Finish +1
- Jet Fighter 27 kills (and every 12 after) +3
- Tank Annihilation - scoring is now defaulted to %1 of Tank Attack Multiball score instead of 2%
- randomized shots during non-competition play (never the same shot back to back)
- Under Flipper 30% of the time
- Left Ramp 20% of the time
- Captive Ball 15% of the time
- Center Spinner 20% of the time
- Right Ramp 15% of the time
- any competition mode active, behavior is left to right (above order)
- Powerline Annihilation - removed randomness during competition games (moves left to right)
- Tank Attack Multiball - Tank shot movement timer starts a 8 seconds and moves down by 2 seconds each Super Jackpot (minimum of 2 seconds)
- Tank Attack Multiball - Tank Jackpots only contribute 50% value to Maser Super Jackpot
- Tank Attack Multiball - fixing an issue where sometimes the Super Jackpot Maser light show would not be running, causing nothing to be lit
- Planet X - Final Shot is now a 20 second hurry up for both first time and Victory Challenge
- Earth Bonus now only gives half of each city's bonus and then the other half will be awarded for the final shot hurry up (if it's not above 55M it will be bumped up to that)
- first time Final Shot is 50M floor and will time out but allows the scoop in single ball play or until the player drains
- Victory Challenge now has a 120 second timer, light the 2nd final shot hurry up before this expires or the mode will end (with killed flippers)
- Victory Challenge Final shot is 50M floor but starts at 2X the first hurry up
- Victory Challenge now has a start display and instructions
- Bonus Collect - display added to show value of bonus collected from Godzilla Powerup
- Destruction Jackpot - grace period shortened 1 second since powerup now extends it by 3 seconds
- Rage Combo - Light Ally award starts at 3-way, the next combo it is awarded at 4-way, the next combo 5-way and then it is no longer awarded
- Bridge Attack Multiball - 1M boost each multiball start
- Select City - new Xilien video added when transitioning to a new city
- Allies - added the ability to stack up to 3 lit allies at the same time
- Allies - Rodan insert now does a timedown flash when it's running
- Allies - Mothra flasher now pulses when Ally is lit and flashes when Allies are awarded
- Anguirus - don't allow Anguirus Add-A-Ball during Godzilla Multiball intro
- Rodan - pausing Rodan Playfield X timer when Saucer Atack Multiball starts
- Magna Grab - fixed an issue with Lock is Lit grabs where it was not using a high powered settings and was causing an unsuccessful grab occasionally
- Monster Rampage - added +1 Destruction Jackpot as second award instead of Extra Ball
- Heat Ray - fixing issues in Godzilla Multiball, Mechagodzilla Multiball, Tank Attack Multiball where Jackpots and Super Jackpots could be collected on the same Heat Ray
- Super Train - fixed an issue where intro display effects were never being displayed properly
- Super Train - added Light Ally award when Train Jackpot is awarded
- End of Ball Bonus - powerups 300K to 100K / fighter 150K to 200K
- Callouts - adding many more callouts to the game
- Sound Effects - adding many more sound effect to the game
- Light Shows - adding many more light shows to the game
- DJ Mixer - added Planet X Multiball tune
- Adjustment Changes:
- added "PLANET X HURRY UP TIMER" default:20 min:18 max:30
- added "PLANET X VICTORY CHALLENGE TIMER" default:120 min:60 max:140
- changed "TANK ANNIHILATION SCORING PCT" default from 2 to 1
- System - Updated to V3.11.0 on OS: V2.6.0
- Updated to nodeboard firmware/protocol v0.85.0
- Fix game reboot issue at power on with coindoor interlock switch in the open position.
#8838 2 years ago
Quoted from gumnut01:
Loving this update, on paper, can't wait to play it.
#8839 2 years ago
Keith is “the sacred beast of the apocalypse”!!
Loading now. This is a big one.
#8840 2 years ago
Oh yeaaaaa baby. This makes the almost impossible wait for my "March" Pro EVEN MORE IMPOSSIBLE.
#8841 2 years ago
If only Ultraman's UI got this level of care..
Edit: as I was trying to call out the UI update specifically but got distracted by my chidren
#8842 2 years ago
Quoted from TechnicalSteam:
If only Ultraman got this level of care..
You compare any pinball game up to GZ and most are going to lose, especially a game from a boutique company. Ultraman doesn't have to match GZ to be a good game and code is improving.
11
#8843 2 years ago
Quoted from manadams:You compare any pinball game up to GZ and most are going to lose, especially a game from a boutique company. Ultraman doesn't have to match GZ to be a good game and code is improving.
To be fair, Ultraman loses when compared to ANY game. Not just Godzilla.
#8844 2 years ago
Quoted from GroggyFrogFace:
Feel your pain. I just finishing installing and I’ve been called to a last minute job. Bugger!!
#8845 2 years ago
Playing now and I am so impressed The UI improvements are another win for this game. Still working through scoring, but so far so good.
#8847 2 years ago
Wow another great update.... Power ups added and lots other stuff. .. still so much more coming but there is a reason this game has stayed no1 since released...... its so so good.
#8848 2 years ago
Really dig the UI updates. I wonder what 1.0 is going to look like. This game is quickly becoming my favorite all time Pin.
#8849 2 years ago
Please Stern - get Godzilla's back on the line so us 'patiently' waiting for ours since September can start enjoying this masterpiece!
#8850 2 years ago
How does it keep getting better - lovely! Even the small stuff like the sound when you hit the left ramp is really cool.
$ 9,499.00
Classic Game Rooms
$ 45.00
Chrome Candy
$ 125.88
ChainsawMods
Inscribed Solutions
Game Room Info Shop
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 185.00
Sparky Pinball
€ 168.00
Lighting - Backbox
Watssapen shop
$ 135.00
Performance Pinball
$ 45.00
Inscribed Solutions
$ 80.00
Pin Monk
JuanSolo's modshop
$ 80.00
Reflex Mods
Rancho Cucamonga, CA
Trade
Machine - For Trade
Blacklick, OH
Slipstream Mod Shop
Filament Printing
$ 45.00
Inscribed Solutions
Pinhead mods
13,600
Forest Hill, MD
$ 85.00
Performance Pinball
$ 19.95
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/177 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
