I’ve got an LE I’m considering selling/trading if you know anyone looking…pm me.
NEW CODE YOU GODZUKIS!
V0.90.0 - January, 27th, 2022
- Coin Switch - fixed an issue where the coin switch would not debounce properly when coins were inserted too quickly
- Skill Shot - added new skill shot type for plunging directly to the Pop Bumper
- Skill Shot - separated boost scoring between Secret and Normal Skill Shots
- Skill Shot - shot directly to the Skill Shot insert or Pop Bumper doesn't boost
- Skill Shot - Mecha Lane Skill Shots boost 250K
- Skill Shot - Secret Skill Shots boost 2M
- Skill Shot - removed 1M boost for all Skill Shots
- Planet X - added this new wizard mode available at the City Select when you play all of the Tier2 Battles
- Hedorah / Smog Monster Frenzy - added this new mode available at the Mystery award when you collect 2 Secret Combos
- Rage Combo - added a 5-way combo that starts when the Left Inlane insert is lit
- Rage Combo - shot sequence: Right Ramp -> Left Ramp -> Center Spinner -> Loop -> Tail Whip
- Rage Combo - 3M starting value and multiplies for each successful shot
- Rage Combo - +1M to starting value each subsequent start
- Rage Combo - complete 3 of 5 combos to Light Ally
- Rage Combo - complete 5 of 5 shots for 20M bonus on top of current value + Destruction Jackpot X
- City Combos - added combo info text to the award so you know what combination of shots was used to achieve it
- City Combos - added combo shot instructions to the Instant Info screen
- Secret Combos - added 10 secret combos
- Imposter Battle - up to 4 awards available when dropping the ball from a Magna Grab into left lane
- Imposter Battle - Award 1 - 15M + Light Ally
- Imposter Battle - Award 2 - 20M + Annihilation Bonus boosted +1%
- Imposter Battle - Award 3 - 30M + Destruction Jackpot X
- Imposter Battle - Award 4 - 250M
- City Carnage Bonus - added this new countup after leaving a City, bonus points are given for accumulated Annihilation bonuses for Powerlines, Tanks, and Bridge
- City Carnage Bonus - 1X multiplier is added for each running Annihilation Bonus that hasn't drained out yet
- City Carnage Bonus - an additional 1X multiplier is added for completing all the Objectives in a city before leaving
- Earth Bonus - added this new countup after leaving the final City, after this award the game will proceed to Planet X Multiball
- Godzilla Controls Perks - added Perks for Godzilla controlling specific cities as well as controlling a number of cities
- Godzilla Controls Perks - each city Godzilla controls gives a permanent +1 Bonus X
- Godzilla Controls Perks - 1st city controlled - 5M and +3 Godzilla Powerup
- Godzilla Controls Perks - 2nd city controlled - 10M and Extra Ball
- Godzilla Controls Perks - 3rd city controlled - 20M and Heat Ray speedup
- Godzilla Controls Perks - 4th city controlled - 40M and +15M Destruction Jackpot base value
- Godzilla Controls Perks - Tokyo controlled - Annihilation Bonus boosted +1%
- Godzilla Controls Perks - New York controlled - +2M Saucer base value
- Godzilla Controls Perks - Paris controlled - +500K Loop value
- Godzilla Controls Perks - London controlled - +4M Destruction Jackpot base value
- Destruction Jackpot - added countdown speech
- Destruction Jackpot - added a Destruction Jackpot Builds display effect that shows when the multiplier is incremented
- Destruction Jackpot - now permanently boosts Annihilation Bonuses by 1% when collected
- Destruction Jackpot - improved lightshow and sound effects
- Annihilation Bonus - Powerlines adjusted down to starting percent of 2%
- Annihilation Bonus - Tanks adjusted down to starting percent of 2%
- Annihilation Bonus - Bridge adjusted down to starting percent of 4%
- Annihilation Bonus - now available for Tanks and Bridge during a multiball, was previously not the case
- Godzilla vs. King Ghidorah - fixed an issue with the final award display not showing the correct value for the time bonus
- Mechagodzilla Multiball - fixed an issue with the ball saver where it was not consistently saving the ball
- Tank Attack Multiball - base jackpot now carries over from multiball to multiball
- Jet Fighter Attack - added Destruction Jackpot +1X award at 15 Jets destroyed instead of Godzilla Powerup +3
- Loops - lower Destruction Jackpot awards to 25 and 65 loops
- Loops - fixed an issue where Consecutive Loop Champion would not always be updated on multiplayer games
- Super Train - fixed an issue where Super Train Jackpot Champion would not always be updated on multiplayer games
- Rampage - shot count will hold over if Extra Ball was not earned
- Heat Ray - now enters a "cooldown" state when finishing a Super Spinner in Tier 2 Battles or Multiballs, once the mode ends the Heat Ray can be built up again
- Super Spinner - added 25M max spin value / 50M if playfield 2X is running
- All Tier 1 Battle Modes - if a Battle is not completed on the first try, the time remaining per second bonus is lowered from 500K to 50K
- All Tier 1 Battle Modes - final shot now totals up the the finishing bonus formula for seconds left in the mode
- Godzilla vs. Megalon - balanced scoring
- Godzilla vs. Megalon - improved shot grace handling
- Godzilla vs. Megalon - shot timer will now pause when game events hold up the ball
- Godzilla vs. Ghidorah and Gigan - fixed an issue with the final award display not showing the correct value for the time bonus
- Godzilla vs. King Ghidorah - scoop shot now only collects at 1X jackpot value
- Mystery - fixed an issue where Mystery would award Light Battle when it was not allowed in the current city
- Shoot Again - can now be interrupted by Skill Shot displays when awarded
- Tilt - added a Minilla Tilt / Danger theme in addition to the Gigan / Megalon that already exists
- Callouts - adding many more callouts to the game
- Sound Effects - adding many more sound effect to the game
- Light Shows - adding many more light shows to the game
- DJ Mixer - fixed an issue where attract mode would say the game was set to DJ MIXER mode which is not a valid default game mode.
- Adjustment Changes:
- fixed AD_BACKBOX_SPEAKER_TYPE_CHANGED to be overriden for PRO models in case someone installs a 4 ohm speaker
- added "HEDORAH SWITCH HITS" default:100 min:50 max:150 - controls how often Hedorah Jackpot is lit
- added "PLANET X MB BALL SAVE TIMER"
- changed "BRIDGE ANNIHILATION SCORING PCT" default from 8 to 4
- changed "POWERLINE ANNIHILATION SCORING PCT" default from 3 to 2
- changed "TANK ANNIHILATION SCORING PCT" default changed from 3 to 2
- System - Updated to V3.04.0 on OS: V2.6.0
- Updated to nodeboard firmware/protocol v0.83.0
- Insider Connected attract mode screen updated to display the location name and green check mark with
Verified Location if the machine is registered to a pro account.
Wow! Wizard mode, combos (and secret combos), skill shots, control perks... Awesome! Can't wait to fire this one up!!!!
Quoted from DeathHimself:Whoot downloading now... 13 mins download awesome!
Dang ! I thought I had fast internet.
Yours is turbo charged.
Quoted from Wariodolby:Dang ! I thought I had fast internet.
Fios 1 gigabit connection, plus my machine is hard wired into a switch, not using the wifi dongle.
The most time consuming part is the game code update of the Spike II CPU board to complete, download was quick.
I'm thinking of ordering the Pro and was told by the distributer I wouldn't get it until March.
Any opinions if this new code update would already be installed in the new Pro builds?
Quoted from gjm:I'm thinking of ordering the Pro and was told by the distributer I wouldn't get it until March.
I would certainly imagine so. If not, a USB drive and 20 or so minutes and the newest code is uploaded. Guaranteed the code is going to change/update/improve several more times from here. So happy for the new code! Can't wait to try it out!
Honestly a little surprised to hear there's any availability left in the March run
First time wifi downloading. Slow as crap and im on gbit internet with awesome wifi reception. My game only came with the small USB dongle wifi adapter and those things suck.
Quoted from mbrave77:First time wifi downloading. Slow as crap and im on gbit internet with awesome wifi reception. My game only came with the small USB dongle wifi adapter and those things suck.
Yeah, I made sure to turn the machine on in hopes I'll get a game or two in tonight. Takes me hours even on gigabit and I have a network extender in the same room
Quoted from mbl1116:Honestly a little surprised to hear there's any availability left in the March run
I spoke with Melissa at Cointaker and Colorado Game Exchange yesterday.
You won’t be disappointed. Great mods to add that make the pro even better! Love my pro. Never leaving.
Quoted from BallyKISS1978:You won’t be disappointed. Great mods to add that make the pro even better! Love my pro. Never leaving.
I don't even have the pin yet and I already ordered all of the mods from Tididdy.
I wanted that limited run for the building he's going to make, I have building 1017
Quoted from CashMoney:Who else feels me on this one?
Watching an Waiting Kermie
Quoted from ArcadeAction:Mod installed: here are a couple photos showing Lit Kit Flippers on Godzilla
[quoted image][quoted image]
Wow, those look great!
Which distro is this? PM is fine if you don't want to say openly.... Just mulling between a pro and premium.
Karl at iepinball is streaming the new Godzilla code tonight starting at 6pm PST. Both his beta stream earlier locked up a couple times, let's see if they fixed it for 0.90! He really gives the code a workout.
He's still giving away pinmonk fans and t-shirts on this and every stream this month. Get into the stream within the first 30 minutes and type !contest in the chat to get a link to the entry form for the contest. The contests are a guess relative to the night's stream achievements. Whoever comes closest wins. The winners are chosen later in the stream.
Stream is here, starting at 6pm:
https://www.twitch.tv/iepinball
Quoted from PinMonk:Karl at iepinball is streaming the new Godzilla code tonight starting at 6pm PST. Both his beta stream earlier locked up a couple times, let's see if they fixed it for 0.90! He really gives the code a workout.
Thanks for sponsoring this. I had a fun time watching the first night (and I won!).
Quoted from Sleal16:The material color makes it hard to take a photo of, but this is the mounting piece thats screwed onto the pop bumper. Underside of the UFO has a hole with corresponding lips that falls into those openings and twists in to place.
Other options were 3M tape or magnets to make the design screw-less from above, but felt this would be more secure in the small chances of airballs hitting it.
You did a GREAT JOB WITH THIS MOD! I just installed mi e the other day, before hand I decided to paint segments inbetween the top and bottom parts of the Saucer to make it appear more like the top half of the mod. Looks great after a few coats and that thing isn't going anywhere! Can't wait to obtain the Mechagodzilla shield mod and your others my friend! A true gift you have with design and you're not out to empty our wallets which IMO will gain you more sales in the long haul. I appreciate your efforts and quality workmanship. Thanks again Sergio!
20220124_175549 (resized).jpgQuoted from Frax:Which distro is this? PM is fine if you don't want to say openly.... Just mulling between a pro and premium.
Cointaker & Colorado Game Exchange. Also Automated pinball.
This code update is huge. Tons of new speech, rules, animations and (most exciting to me) light shows. Great job software folks.
Wasn’t Godzilla vs Hedorah one of the few movies from the era this game is based on they couldn’t use? He’s shown up in a new custom 3d animation. I guess they could use the character but not the clips?
Quoted from gjm:Cointaker & Colorado Game Exchange. Also Automated pinball.
Ah okay, didn't realize Pros in general weren't so backed up as premiums...
Quoted from gjm:I don't even have the pin yet and I already ordered all of the mods from Tididdy.
Awesome. Good to have everything you need when it gets there. Plenty of great mods. Here’s a video I took of my mods. I also installed a jet fighter and Mothra see pic. Going to install minya when it’s released.
06A2AC7F-E309-4400-8742-92EA0D64490E (resized).jpeg3E80A9F9-028C-408A-A1F2-8166A6A8DF24 (resized).jpeg40645F31-39E4-40E0-9DD9-C467AD899AEC (resized).jpeg
Quoted from KingVidiot:This was a nice touch on the new code update
Thats awesome
Quoted from Had:Did anyone's speakers make a large pop noise during the update reset? Mine went off twice.
You won the lottery! Sorry I couldn’t help it….
it did that for both of the updates i've applied on my premium. seems to be a semi-common thing.
Quoted from Jkush18:Nice tribute to Lyman in the new code!
Shows up for me as LYMAN, with the 10-character option enabled. Lovely tribute, for certain.
Quoted from Muymanwell:it did that for both of the updates i've applied on my premium. seems to be a semi-common thing.
Yeah, seems to do it whenever it resets during code updates. All good.
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-official-owners-club/page/140 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
