Quoted from dboeren:Has anyone managed to find a King Ghidora figure in the 6.5" tall range that can fit in the back of the playfield? I was thinking standing over the center spinner lane would be a good spot.
I recently added a King Ghidorah to the right rear corner of my machine. The figure I bought is a "Trendmasters Ghidorah" from 1994. Do a search on eBay and you'll find a couple.
It's basically made of rubber so the wings vibrate a bit, which I like. The legs, tails, wings, and necks have wires internally so you can bend / position things the way you want. The one I bought was kinda greenish in color so I painted it metallic gold.
Mounting was easy enough. If you look in the right rear corner of your machine in the area below the building on the backwall, you'll find a locknut holding down the plastic. I replaced this with a 1.5 inch post. I then jammed a wire up Ghidorah's butt, formed a loop in the other end and mounted it to the post.
I think it looks like it belongs there and is a great compliment to Godzilla on the other side of the machine.
