Quoted from digitaldocc:As a big fan of powerbladez I added a set to my godzilla. However, to make that animation more special I'd only like it to fire up when the red GI is active.
Does anyone know how to hack that inverter box to turn it on and off without having to control the 120v input? I can't seem to find a relay to tackle the 120v on/off with a low voltage trigger such as the GI.
Below is what it would look like with the red GI. The best part is the begining flames animation.
I've never seen them in person, but i'm guessing powerbladez use EL wire to create that effect? If so that would mean that the inverter box you're talking about is AC, so 120VAC - just to add to the complexity even more .
Looks like there's a couple of options. This opto/triac one looks decent
https://www.electro-tech-online.com/threads/how-do-i-use-5vdc-to-switch-120vac.119977/
Further down are some discussion around solid state relays that would do the job also, like the S108T01F.
I did some lower level (6.8VAC) AC triggering on the Chase Echo using n-channel power mosfets, with two mosfets wired together to achieve trailing edge dimming. I have no idea if EL wire can be dimmed like that, but wouldn't it be great if powerbladez could get some nice fadey effects going.
