(Topic ID: 300951)
Stern Godzilla Mod Thread
By Lermods
2 years ago
There are 5,247 posts in this topic. You are on page 27 of 105.
#1301 2 years ago
My Mechagodzilla is the Bandai 8” 1995 reissue of the 1983 version. The only difference from this one and the 1983 version is that it is all silver compared to the 1983 having some black on it. It measures 4” tall cut in half. You could fit up to a 5.25” figure in there and be just under the glass.
1F9287BA-C4CD-4346-ACFC-96A6AD43DD8B (resized).jpeg1F9287BA-C4CD-4346-ACFC-96A6AD43DD8B (resized).jpeg8CDB73E2-9CFB-4E07-99C3-A9F5E4E295D7 (resized).jpeg8CDB73E2-9CFB-4E07-99C3-A9F5E4E295D7 (resized).jpeg
#1302 2 years ago
Quoted from Cwells3290:
[quoted image][quoted image]
Oh cool. I might have mis-measured the area on my LE. Couldnt get the darn bash toy on that off to try it on with the glass. Should get it in a Pro sometime soon. At least this one, just for looks check until I make the next cleaner draft.
#1303 2 years ago
Quoted from Pugster:
Lighting bottom up through that “splash” may just be the ticket…nice find!
That's kind of what I was thinking as well. One of those comet star post lights is easily hid under the bottom of that. Looks pretty sweet, unfortunately the piece was pre-painted with white enamel on the tip of the breath and the top and bottom of the splash. So although the LEDs luminate the base they don't travel up the column of breath the way I would have hoped. I have a few ideas for some workarounds. Still like it 100% better than the red breath.
#1304 2 years ago
Quoted from Strummy:
OD parts are being cast. Chrome next
Will you be selling these?
#1305 2 years ago
Quoted from Sleal16:
You may be able to get away with 5.5” tall depending on the location of where the tallest point of the figure is located. By the way I am looking forward to getting my saucer mod from you.
#1306 2 years ago
Quoted from Jimmyhonda:
Yep. Taking a while because of the older methods.
#1307 2 years ago
Quoted from gripwhip:
Are we sure this one fits? I thought it had to be under 6.2" or something?
Well it fits fine in my Godzilla premium. If your that scared don't buy it.
#1308 2 years ago
not sure why they listed it as 7"...from the description: "Godzilla stands approximately 6" tall and measures 12" long from head to tail"
most of these neca figures are right around the same size, and have some decent articulation, so you can adjust them a bit to fit. the poster godzilla bonks his head on the glass if he's too forward, in example, but you can shift him back, or bend him down a bit, to make up for it.
#1309 2 years ago
Quoted from teddyb73:
Just getting confirmation that it was the right one and will fit. I have read about other Neca models being used too. Thanks.
#1310 2 years ago
That's the best one to buy. He is an authentic looking Godzilla like the one in the movie clips. And to be honest he fits in there just perfect. You just have to bend his tail up along the building in the back.
Also it comes with the tail detach from the main figure. To snap that tail in is a real pain in the butt. You got to use dishwashing liquid soup to lube the ball joint up before you snap it in the socket.
14
#1311 2 years ago
Almost there! This thing is heavy. Chromed pewter
#1312 2 years ago
Looks like a must have mod. , I would like one .
Is a picture of this mod inside the machine possible ..thanks
#1313 2 years ago
I need this. How did you attach it?
#1314 2 years ago
I'm having trouble aligning the back left habitrail with the building. My building seems too low or the ramp too high. Can some post a picture of the back GZ Pro building.
#1315 2 years ago
#1316 2 years ago
Quoted from Av8:
The figure is hollow inside so I cut a circle the size of the bottom out of 3/4” thick wood. I applied glue inside the figure and pressed the piece of wood into place. After you remove the plastic Mechagodzilla you are left with two holes on the mounting plastic in your machine. Position your new Mechagodzilla where you like it and use the two holes in the mounting plastic as a template to mark your drill holes in the wood. A couple small wood screws with washers and you are done.
#1317 2 years ago
Quoted from Mookie:
I'll be installing it soon and will post pictures.
#1318 2 years ago
So... I'm working on the rooftop mod and I'm curious as to the height of these spacers and if there are any washers? I've downloaded the manual and I don't see any specifics as to these parts. If anyone knows or has the glass off and could measure, I would truly appreciate it.
Screenshot_20220411-155229 (resized).pngScreenshot_20220411-155229 (resized).png
#1319 2 years ago
https://amzn.to/3v9ZXX9 Cheap easy Sub woofer upgrade. Pyle 8 inch 4 ohm. Use 1 inch drywall screws to mount to cab. Only 28 bucks.
Volume control install.
#1320 2 years ago
New Godzilla Pro with Playfield Protector. Day 1 gameplay. Love this machine. Also Pyle Subwoofer demo. HD Glass.
#1321 2 years ago
Quoted from Av8:
Looking great man. If you really want the cabinet sub to work well I'd highly recommend an external amplifier. They're inexpensive, and make imo more difference than changing the actual woofer!
#1322 2 years ago
Quoted from Good-Times:
Im impressed so far with the Pro sound sys. You just need to tweek settings alot. The Pyle sub is rattling the glass without the amp, so thats a good sign. What back box speaks would you recommend for the replacement on the GZ Pro? Stock is 4 inch I believe.
Im studying the rules now so I can make better gameplay videos.
https://sternpinball.com/wp-content/uploads/2022/03/Godzilla-Rulesheet.pdf
#1323 2 years ago
FYI. The Avengers IQ lit Stern shooter Rod works and is interactive with GZ. Looks better than GZ version imo.
#1324 2 years ago
Would these Pyle 4 inch work/fit the Pro? They are a good value at 28.00 Looks like I just need a spacers.
https://amzn.to/36463zN
4" Car Sound Speaker (Pair) - Upgraded Blue Poly Injection Cone 2-Way 180 Watt Peak w/ Non-fatiguing Butyl Rubber Surround 110 - 20Khz Frequency Response 4 Ohm & 3/4" ASV Voice Coil - Pyle PL42BL
#1325 2 years ago
I'd suggest the Kicker CSC44 (4") or CSC54 (5" if you want to get an adaptor plate for them).
#1326 2 years ago
ebay.com link: itm
Here is the Godzilla I add to my pro. 17 USD. Just clip his tail and screw to the plastic.
#1327 2 years ago
Over priced imo. Stern LE Kenmores are 40 a set on Pinballlife.com.
#1328 2 years ago
Yeah strangely they're a lot cheaper in Australia relative to the Kenwoods, but honestly anything is going to be better than standard!
#1329 2 years ago
Did a little mod-combination with two UFO-mods (two for one).
3M double sided transparent tape was the solution.
20220412_155723 (resized).jpg20220412_155723 (resized).jpg20220412_155746 (resized).jpg20220412_155746 (resized).jpg
#1330 2 years ago
Ty
#1331 2 years ago
I added an alternate translight to my Pro
#1332 2 years ago
Quoted from Av8:
Yes see my post. I used the included spacers that came in the box.
https://pinside.com/pinball/forum/topic/improving-sound-quality-the-diy-route/page/2#post-6731065
#1333 2 years ago
Quoted from Apinjunkie:
Asked and answered, thanks Sleal16
#1334 2 years ago
Kenwoods are $40 delivered in Australia.
#1335 2 years ago
Quoted from gumnut01:
Never seen them under $50 plus postage, Kickers are $84 posted. In the US, the Kickers are double (or more) compared to the Kenwoods. Anyway, comes down to budget and preference.
#1336 2 years ago
Still working on it
Screenshot_20220413-123046_Gallery (resized).jpgScreenshot_20220413-123046_Gallery (resized).jpg
#1338 2 years ago
looks great! You really put a lot of effort into it, and it shows
#1339 2 years ago
Great job. Gotta have one. Anxious for its release.
#1340 2 years ago
Can't wait for the release so I can buy it.
#1341 2 years ago
Ummmm, yeah, that's sweet. Me need one of those.
#1342 2 years ago
Awesome job, count me in as well! Looking forward to giving you my money!
#1343 2 years ago
Awesome..wow i need this mod.
Thank you for sharing this .
I like to purchase one from you.
#1344 2 years ago
In as well
#1345 2 years ago
Looks great im in
#1346 2 years ago
I am in as well. Fantastic mod!
#1347 2 years ago
Very nice, how much? and does it go on same place as Lermods one?
#1348 2 years ago
Thanks for the kind words about the Od mod. Hopefully I will put it on my game as soon as I have time in the next few days.
I owe the design to my Friend Jason Bakutis who made the youtube video above. Look him up. he does amazing work.
#1349 2 years ago
I believe that the 1st batch is 11. We haven't priced it yet so that is why I haven't offered it for sale yet. I already have a list started from PMs though. Here it is. Please pm with a yea or ne if you see your name. Thanks
Qbass187
arcadem
Toolpro
Skooter710
ODtank
JimmyHonda
Toolpros
Freddy
Mackarov
Zora
Faust
Cwjumper
Thanks everyone
#1350 2 years ago
Quoted from RPZ:
Please see post #1019 for where it is mounted
YouBentMyWookie
$ 114.99
$ 74.00
Hookedonpinball.com
16,000
Mt Zion, IL
9,000 (OBO)
$ 2.00
Chrome Candy
$ 125.00
Cabinet - (Alt) Translites
PINBALLPICKERS
$ 17.99
Playfield - Plastics
$ 159.99
Maine Home Recreation
arcade-cabinets.com
Daddio's 3D Printed Mods
€ 50.00
Pino Pinball Mods Shop
O'fallon, IL
Chrome Candy
€ 55.00
$ 34.95
Discos Pinball Mod Shop
$ 210.00
12,700
Forest Hill, MD
$ 80.00
Reflex Mods
$ 16.00
€ 99.00
Lighting - Under Cabinet
Watssapen shop
Filament Printing
This page was printed from https://pinside.com/pinball/forum/topic/stern-godzilla-mod-thread/page/27 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
