My TRON LE (2nd owner) has blown the 3A slow blow fuse on the right flipper coil. I replaced it this morning and it blew as well.
Symptoms. It seemed to hum when the flipper button was held down. I investigated the humming a little bit. Flipper switch and EOS are both functioning properly before and after the 3A blown fuse. I noted that both left and right flipper hummed a little when the buttons were held down but not a loudly.
History of machine.
1. The spinning disk motor was not functioning properly and the previous owner had what her called a "transistor pack" replaced. Its a component of 4 ceramic bricks with power going in and out and leads to the spinning disk motor.
2. I have added some mods; arcade, flynns sign, LED flipper buttons.
Any help is appreciated.
