My 1980 Stern Flight 2000 will not turn on after turning the game off at the switch and power strip. A little back story on the game i got it crazy cheap even though its in great shape because it hadnt been played in a long time and was blowing the 1amp slow blow under the playfield. This is my first solid state game have 3 others but they are em. After getting it home and a good cleaning/re ring and new balls i started to dive into it to see/correct why it was blowing the fuse. On visual inspection the power rectifier board and solenoid driver board looked like they had seen better days, could tell it had been hot and was starting to burn. So i instantly decided to eliminate alot of headache (so i thought ) i would just change all the boards. After a few days the parts arived and I put in a brand new alltek ultimate mpu, a rebuilt solenoid driver board and a brand new rotten dog power rectifier board and boom played like a brand new machine no more blown fuses. Out of the garage and into the house it went. Myself my kids and friends played tons of games and everything worked flawlessly until friday. I turned the game off at the switch and on my power strip and went to bed. Saturday morning wake up and go to power the game up for the kids to play and i get nothing but the general ilumination. Open the head and try again so i can watch the led on the mpu once agian nothing but gi NO led on mpu at all not solid not flashing nothing. I get my meter out and check all my test points on each board and find everything within spec aside from no +5vdc at the mpu board or at tp1 on the solenoid driver board. i have +43vdc line in at the mpu and at the tp I also have +12vdc at the wire going into the solenoid driver board but no +5vdc at tp1 on the solinoid driver board so was thinking i had a bad voltage regulator or cap so i swapped in a known good board but it still will not boot no led on mpu no +5vdc at tp1 on the known good solenoid board or at the mpu. Which makes no sense to me any thoughts/ help are greatly appreciated
