(Topic ID: 337587)
Stern flight 2000 Pop Bumper Rebuild Question
By suntester
10 months ago
  • 7 posts
  • 6 Pinsiders participating
  • Latest reply 10 months ago by swinks
    #1 10 months ago
    Hi All.
    Bought a Flight 2000 and doing some work.
    The pop bumper housings were cracked and I got new ones from Pinball Life. The pop bumper rod & ring assemblies are plastic and the normal fiber and metal yokes are plastics too.
    They are not broken, but I would rather use new parts and I don't see new plastic parts anywhere.
    Also, someone used a little grease on the plastic yokes which I assume is not the way to do it?
    So will metal rod & rings and metal and fiber yokes work ok?
    Thanks, Mark
    #2 10 months ago
    New plastic parts are available from Swinks shop on Shapeways. To use the plastic parts with the new base you'll have to drill the rod and ring holes in the base oversized for the plastic rods. This would be my preferred option since the plastic parts have less mass and snappier performance.
    https://www.shapeways.com/shops/dutch-orange
    I don't know about just replacing the plastic parts with metal. The plunger and stop bracket may not be compatible, you may need to buy these parts as well, but I don't know, I've never done this conversion.
    #3 10 months ago
    If you convert it the plastic parts to new metal ring/rods you’ll need the metal and fiber yokes. They’ll work just the same. The plastic yokes are shaped to fit the plastic rods, so they’re incompatible with the more common metal ones.
    I’ll be the first to throw my hat in the ring to buy the used plastic ring/rod and yokes from you however!
    #4 10 months ago
    Thanks guys - everyone else - send your opinions & thoughts.
    Mark
    #5 10 months ago
    I'd keep the original plastic parts if they are still in good condition. As mentioned above they are nice and snappy.
    #6 10 months ago
    As long as there's no wear/play, keep the original plastic. They don't need replacing as bad as the metal
    #7 10 months ago
    Here is a better link for just the pop bumper parts I helped people with:
    https://www.shapeways.com/marketplace?q=swinkscsbumper&sort=newest
    This page was printed from https://pinside.com/pinball/forum/topic/stern-flight-2000-pop-bumper-rebuild-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
