(Topic ID: 274711)
Stern Elvira HOH bill validator coining problem
By Yilb
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Yilb
#1 3 years ago
Video showing what happens:
Sees all switch closures in test mode fine, in attract mode usually sees 4, sometimes 3, and very rarely will see 2 or all 5.
Have switched node board, no change, have switched main board, no change.
Running .98 latest code.
Tried a different validator, no difference.
Have used these validators on many new sterns, including stranger things with no problem.
Called stern, not accepting calls, have called direct contact, no return call, have sent email, no response.
Hope to try in a different Elvira soon, will up date with result.
Any ideas are welcome for consideration. Feel it is a code issue.
#2 3 years ago
Use a long pulse seeing on your bill acceptor setting and it should be fine.
On a MARS you will need to print out a program card.
#3 3 years ago
Thanks for he reply. I'm using the long pulse setting all ready.
#4 3 years ago
Is it an MEI.
#5 3 years ago
Have to check. It’s 12v. They work fine on all the other Stern games I have.
Why would it work in test Mode and fail in attract mode?
#6 3 years ago
all my sterns use a 110v. i only use 12v on JJP, CGC and AP.
#7 3 years ago
The bill acceptor is an IGT. Works on every other game.
#8 3 years ago
IGT? Or an ICT?
#9 3 years ago
ICTs are total garbage... I would definitely try a MEI before coming to a conclusion. Also ICTs need a programmer to program
#10 3 years ago
IGT.typically used in slot machines. Have used them in all my new stern tables with no problems at all. Until now.
I’ll see what I can do to come up with a differently branded acceptor. That doesn’t address the question of why it works in test mode and not in attract mode. Does the test mode just not work on this game?
#11 3 years ago
Updated code to .99, no change. Tried a Mars acceptor, no change. Acceptor works fine in new turtles game.
#12 3 years ago
Update: set acceptor on fast pulse and now it works ok with the .99 code. Does not work on slow setting. Using .97 code will not work on fast or slow settings.
#13 3 years ago
Quoted from Yilb:
So It needs a faster pulse setting ? Hope code helped
#14 3 years ago
I guess so? It seems to be working? I’m still suspicious. Occasionally the game reboots. And on one occasion froze and had to be turned off and back on. The latest code is definitely better, not so many glitches.
Lenticular Designs
€ 99.00
Lighting - Under Cabinet
Watssapen shop
8,900
$ 69.99
Inscribed Solutions
$ 50.00
Duke Pinball
$ 18.00
Pin Monk
$ 10,499.00
Maine Home Recreation
$ 1,075.00
Orange County Pinballs
$ 200.00
Led Pinball
$ 65.00
$ 60.00
Don's Pinball Swag Barn
$ 130.00
Dijohn
$ 10,499.99
Pinball Pro
9,000 (Firm)
$ 40.00
Pin Modster
$ 47.00
Space Coast Pinball
$ 12.95
SilverBall Designs
Filament Printing
$ 1,099.00
Paradise Distribution
$ 200.00
Led Pinball
10,500 (OBO)
Edgemoor, DE
Pinhead mods
Great pinball charity
Pinball Edu
